E&M Problem - 2 Charged Masses Hanging on Strings
The problem involves two charged masses hanging from strings, with one mass having charge q and the other charge 2q. The task is to find an approximate expression for the angle each charge makes with respect to the vertical, considering the effects of electric and gravitational forces.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the forces acting on the charged masses, including electric and gravitational forces. There is uncertainty about the relevance of mass and how to relate the forces to the angles. Some participants express confusion about deriving the angles from the equations.
The discussion is ongoing, with participants exploring the relationships between the forces and the angles. Some guidance has been provided regarding the equations relating tension, angle, and horizontal distance, but no consensus has been reached on the approach to take.
Participants note that the problem does not specify certain vector details, leading to questions about the setup. There is also mention of a potential mind block experienced by one participant.
inferno298
E&M Problem -- 2 Charged Masses Hanging on Strings
Two charges of identical mass m, one with charge q, the other with charge 2q, hang from strings
of length l from a common point. Assume q is sufficiently weak so that any angle you're looking
for is very small, and find an approximate expression for the angle  each charge makes with
respect to the vertical. Check (and show) that the units work out, and that the limiting behavior
for large mass, large length, and/or small q are at least sensible.
Coulombs Law
E=(1/4*pi*episolon)(q' R/R)
First I am not sure what to do with the mass, if its really even needed.
Also I am given lengths, but it doesn't specify that they are the vectors themselves, otherwise I would just use the r' vector to the charge and the r vector to some random point charge in the middle to grab the vertical angle.
I think there is another way I am missing though. Any help or insight would be appreciated.
First think about which forces are acting on the charged masses. Then your electric field of a charge Q in the origin should read (in SI units)
\vec{E}=\frac{Q}{4 \pi \epsilon_0} \frac{\vec{r}}{r^3}.
So there will be a bigger force acting upon q as opposed to 2q. The angle between the vertical and q will be bigger than the other. I guess I am having trouble relating that into the formula, or even figuring out how to get the angles out of it. I am sorry for the huge mind block that I am experiencing
The electrostatic forces on the two masses are equal & opposite. They're in the x direction.
Remember that gravity also acts on both of them. Equal forces here too. In the y direction.
So the two masses hang the same angle from the vertical.
Call the tension in each string = T
Then write 3 equations relating T, the angle from the vertical θ, and the distance eack mass assumes horizontally from the at-rest (zero electrostatic forces) position.
3 equations, 3 unknowns. Solve for θ.
alright thanks, I almost got it now
  • · Replies 19 ·
