Storing Energy in a Rubber Band: Does Mass Increase?
When a rubber band is stretched, it stores elastic potential energy, which theoretically increases its mass according to the principles of physics. This stored energy contributes to a slight increase in weight, similar to how a charged battery weighs more than a discharged one. The discussion encourages calculating the actual mass increase to understand the concept better. The energy stored in the stretched rubber band cannot dissipate, reinforcing the idea that it equates to mass. Overall, stretching a rubber band does result in a measurable increase in mass due to the energy stored within it.
deadcat
Does this mean if I had a rubber band and weighed it, then stretched and weighed it while being stretched out, that it would weigh more at that time? Since at that time it has stored energy, which equates to mass?
Yes, that is what it means. And a charged battery will weigh slightly more than discharged battery, and so forth.
It is a worthwhile exercise to calculate just how much mass increase we're talking about... Try it!
If you stretch out a rubber band the energy is converted into elastic potential energy. The fact that the rubber band is stretched out proves that the vast majority of the energy cannot go anywhere else, eg. mass.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 26 ·
