Earth’s magnetic field alignment and climate change?
The discussion centers on the relationship between Earth's magnetic field alignment and climate change, exploring whether changes in the magnetic field's orientation relative to solar wind could influence climate at various locations on Earth. Participants examine theoretical implications and potential correlations, while also addressing the nature of solar wind and its effects.
  • Some participants propose that the movement of Earth's magnetic field could change the protection offered to different points on the Earth's surface from solar radiation.
  • Others argue there is no evidence of a correlation between magnetic field changes and climate change, suggesting that solar wind does not influence global temperatures.
  • One participant notes that historical data shows numerous magnetic reversals without corresponding climate changes, indicating a lack of alignment between these phenomena.
  • There are inquiries about existing research on the relationship between magnetic field alignment and solar wind direction, with some expressing skepticism about the relevance of certain data sources.
  • Some participants discuss the temperature of solar wind and its low density, emphasizing that temperature alone does not determine heat transfer effectiveness.
  • Questions arise regarding the potential effects of magnetic field dynamics on climate, with participants expressing uncertainty about any established correlations.
Participants generally disagree on the potential influence of Earth's magnetic field on climate change, with some asserting there is no correlation while others explore the possibility of such a relationship. The discussion remains unresolved, with multiple competing views present.
Participants highlight limitations in the current understanding of the relationship between magnetic field dynamics and climate change, noting the absence of definitive evidence and the complexity of the interactions involved.
BeedS
The Earth’s magnetic field is slowly moving with respect to the Earth’s surface and to the Sun’s incoming radiation and solar wind direction. Does the tilting/moving of Earth’s magnetic field axis to the incoming solar wind direction change the protection on different points of the Earth’s surface?
By the Magnetic field alignment moving can it influence climate change at different points on the Earth’s surface?
There's no evidence of a correlation and no reason to think there should be.
The periods don't even align. In the last 100M years, there has been one ice age and two interglacials - but about 200 reversals.
Ok, so if the magnetic north pole was facing the Sun it would give the same protection as the current alignment does now?
No, but solar wind has nothing to do with global temperatures/warming.
russ_watters said:
No
Do you know of any research done on magnetic field alignment and solar wind direction? I wonder what the bow shock would look like if the magnetic north pole was facing the sun and will the north/south pole funnel the solar wind?
This wiki on solar wind says it's quite hot 80000k
https://en.wikipedia.org/wiki/Solar_wind
Not offhand, but I'm sure some is out there if you look.
Ok... You are aware that we have sent dozens of spacecraft beyond Earth's magnetic field, right? Do they [risk] burn up or freeze?
Um, IIRC, there may be some subtle effects due to UV and cloud-seeding / lightning / sprites etc triggering by radiation.
Given our magnetic poles are currently far, far away from sub-solar zone, the nearest, poor analogue would seem a 'Carrington Event' or equivalent, which have wild aurorae but no apparent climate impact, I got to go with the comment above about lack of correlation between reversals and ice-ages...
BeedS said:
https://www.nasa.gov/sites/default/..._Space_Environment-ISS-Mini-Book-2015-508.pdf
This is for the ISS that's only 400 km away and well within the Earth's magnetic field protection.
That paper is 40 pages long. Can you quote a relevant passage? After a quick skim I don't see any relevance to this discussion.
The solar wind doesn't carry or produce heat and the wiki article is wrong?
The wiki is not wrong; the solar wind carries heat. But it is vanishingly thin, so it carries only a vanishingly small amount of heat. You could probably calculate, from information in the wiki article, how much heat in watts per square meter and compare it to sunlight.
hmmm27 said:
and it doesn't actually appear in the article referenced.
"In near-Earth space, the slow solar wind is observed to have a velocity of 300–500 km/s, a temperature of 1.4–1.6×10^6 K and a composition that is a close match to the corona. By contrast, the fast solar wind has a typical velocity of 750 km/s, a temperature of 8×10^5 K and it nearly matches the composition of the Sun's photosphere."
The solar wind is indeed really hot but the density is very very very low. The temperature is not the only parameter important in heat transfer, the number of particles is also an important criteria.
To have an idea of the magnitude of the energy fluxes in the atmosphere, I suggest you these:
https://www.acs.org/content/acs/en/climatescience/energybalance/planetarytemperatures.html
https://journals.ametsoc.org/doi/10.1175/2008BAMS2634.1
(you can get this paper by searching its title on Google)
@BeedS, are you arguing that the Earth's magnetic field does affect climate change or are you arguing that it should?
I don't know if Earths magnetic field can affect climate change. I'm trying to find out if there is any known correlation or if there is any possibility that it can contribute through magnetic field dynamics.
This question
has been answered more than once
Thread closed.
  • · Replies 46 ·
13K
  • · Replies 28 ·
  • · Replies 27 ·
  • · Replies 18 ·
