Carbon Dating and Half-Life: Calculating the Age of Ancient Objects
  • Thread starter Thread starter joejo
    Half life Life
The forum discussion centers on calculating the age of ancient objects using carbon dating, specifically focusing on carbon-14 (C-14) and its half-life of approximately 6000 years. Participants discuss how to derive equations for the remaining amount of C-14 after a given number of half-lives and how to determine the age of a sample based on its C-14 content. Key calculations include using the formula 32(1/2)^n for remaining C-14 and determining that after 12000 years, 8g of C-14 remains, indicating 2 half-lives. The discussion concludes with the realization that a sample containing 2g of C-14 corresponds to 4 half-lives, equating to 24000 years.
  • Understanding of carbon dating principles
  • Knowledge of half-life calculations
  • Familiarity with exponential decay formulas
  • Basic logarithmic functions for advanced calculations
  • Study the mathematical derivation of half-life equations
  • Learn about the applications of carbon dating in archaeology
  • Explore the limitations and accuracy of carbon dating methods
  • Research logarithmic functions and their applications in decay problems
Students preparing for exams in remedial math, educators teaching carbon dating concepts, and anyone interested in the scientific principles behind dating ancient artifacts.
joejo
hey can someone help me out with this question...I have an test 2mr on this time and don't have any more time to waste. So can someone please show me how to do it...so I can study of it...thanks in advance
Scientist are able to determine the age of very old, naturally occurring items through the process of carbon dating. Carbon dating compares the amount of carbon-14 (C-14) that is present in an item with the amount that would be present if the item were created in the present. The half-life of C-14 is approxiamtely 6000 years.
a) Suppose that a piece of wood is cut from a tree. The piece of wood contains 32g of C-14. Write an equation to determine the amount of C-14 remaining after n half-lives.
b) Determine the amount of C-14 that would remain after 12000 years.
c) Suppose that scientists in the future carefully examine the piece of woor and determine that it contains 2g of C-14. How far in the future has the wood survived? Explain your solution.
The basic form of exponential growth/decay, is
y = Ce^{kt} .
k is positive or negative depending on if there is growth or decay. Start from there.
Each half life, there is half of the amount of what there was before of the substance experiencing the half life (in this case carbon 14).
Originally there was 32 grams, after 1 half life (6000 years), 16 grams, then another 600 year later, 8 grams left, ...
This process works like exponential decay,
original amount * .5^n, where n is the number of half-lives it has had.
to find out the number of half-lives it has experienced, simply divide the total time by the time for 1 half life,
12000 years over 6000 year = number of half lives
for the last question it it a bit trickier, it involve logorithms, but is not too hard if you remember the formula of how to detemine how much of a substance is left,
32 grams * .5^n = 2 grams
divide both sides by 32 to get,
.5^n = 1/16
then solve for n,
log(.5^n) = log(1/16), which =,
n*log(.5) = log(1/16)
divide both sides by log(.5) to get n,
then check the answer to make sure it it right.
we haven't done logs...this is suppose to be a remedial math...I'm looking for someone to answer it properly so I use this question to study from...Can someone please help me out...
You don't need logs to do part c. Just count how many times you need to divide 32g in half to end up with 2g--that will tell you the number of half-lives that must have passed.
im lost...can someone show me how to do it...i need to study of this now...
a) general form a \cdot b^n, so 32(\frac{1}{2})^{\frac{n}{6000}} - "n" is years in this problem
b) substitute for n
c) trial and error without logs :smile:
still lost...i don't get it...im trying to do this correspondance and its very difficult
Lets start with what a half-life is- how long it takes until a substance has lost half its mass.
Therefore, in one half life (in this case 6000 years), half of the mass of the substance will be ‘lost.’ Thus, after 6000 years, only 16g (32/2) will remain.
In another 6000 years (after 2 half-lives), half of this amount will be ‘lost’ leaving 8g (16/2) of the substance.
After the 3rd half-life, half this will be ‘lost’ leaving 4g. And so on.
You should be able to calculate the equation from here for part a.
For part b, 12000 years is equal to 2 half lives. You can use your equation from part a to calculate how much is left after 2 half lives.
For c, what value of n in your initial equation gives the value 2g? Each half life is equal to 6000 years so you can convert ‘half-lives’ to years.
so what would the equation be?
I'm not sure in this forum that we can just give you the equation but you should be able to work it out form the information given. This table should make it clearer.
Number of half-lives
Mass of Carbon-14 (g)​
32 (32/1)​
16 (32/2)​
8 (32/4)​
4 (32/8)​
2 (32/16)​
1 (32/32)​
etc
etc​
Note that to find the mass of carbon, the 32 is divided by roots of 2 (as shown). This should be reflected in your equation.
Show your working towards finding the equation and we can see where you are stuck/have gone wrong.
is that it?
Is that what? Your problem had 3 parts to it. Which one does that answer? And we won't be able to tell you if it answers anyone of those until you tells us what n means!
hallsofIvy you never seem to help people out...
anyways...n is the number of half-lives it has had...is that right Doc G or anyone else that is willing to help...
You're wrong. HallsofIvy always helps people out, and he's trying to get you to learn something instead of spoon-feeding you the answer.
"n" in multiples of 6000 would equal the number of half-lives gone by in the equation you posted, so what does that tell you about what n represents?
the number of half lives...my test is 2mr...can someone please answer it...its almost 2am and i don't get half life questions
All I can do is repeat what people have already told you:
"half" life means exactly that- the time required for the amount to halve. To find the amount remaining after n half-lives, you multiply by 1/2 n times.
The equation is just 32(1/2)n.
You are told that the half-life of C-14 is about 6000 years. 12000 is two half-lives.
Multiply by 1/2 twice (0r 32(1/2)2)
The piece of wood starts with 32 g and eventually has only 2 g. It has 2/32= 1/16= (1/2)4 as much as originally. That means 32 is multiplied by 1/2 4 times. How many half-lives is that? How many years?
thanks hall of ivy...as for that below...
there are 4 half lives...making it 8 years correct?
The piece of wood starts with 32 g and eventually has only 2 g. It has 2/32= 1/16= (1/2)4 as much as originally. That means 32 is multiplied by 1/2 4 times. How many half-lives is that? How many years?[/QUOTE]
No. How long is one half-life?
375 years...my test is in 5 hours...can someone please just check my answer and if its wrong state the correct answer...i've been up all night...thanks
Quoting the problem statement in your first post:
therefore the answer to c) is 375 years.
How did you arrive at that answer?
my test is in a few hours...if your planning on helping me out stop confusing me...you could help by telling me what the answer. thanks
If asking how you got your answer confuses you, there's not much I can do.
Try this for problem c. Answer each question in turn:
1) How many half-lives did it take to get from 32g to 2g?
2) How long is each half-life? (that's given)
3) What total time must have passed? (multiply!)
1) 16 half lives...
2) 6000 years
3)96 000 years..
is that right
joejo said:
1) 16 half lives...
That part's incorrect. You've already answered this before! See posts 17 & 18.
4 half lives...is the rest right?
or is it 24000 years now... because 6000*4
That is correct: 4 half-lives equals 4*6000 yrs = 24,000 yrs.
  • · Replies 20 ·
9K
