Easy Physics P=mv momentum (please answer)
  • Thread starter Thread starter Gorn
    Momentum Physics
The discussion centers on the physics equation for momentum, P = mv, where P represents momentum, m is mass, and v is velocity. The user explores rearranging the equation to M = P/V and examines scenarios with varying values of momentum and velocity. It is established that increasing momentum while keeping velocity constant results in an increase in mass, contradicting the user's initial assumption. The correct interpretation is that an increase in momentum correlates with an increase in mass when velocity remains unchanged.
  • Understanding of basic physics concepts, specifically momentum.
  • Familiarity with algebraic manipulation of equations.
  • Knowledge of the relationship between mass, velocity, and momentum.
  • Basic comprehension of units of measurement in physics (e.g., kg, m/s).
  • Study the principles of conservation of momentum in physics.
  • Learn about the implications of mass-energy equivalence in relativistic physics.
  • Explore real-world applications of momentum in sports and vehicle dynamics.
  • Investigate advanced topics such as impulse and its relation to momentum changes.
This discussion is beneficial for physics students, educators, and anyone interested in understanding the fundamental concepts of momentum and its implications in various physical scenarios.
Gorn
Hello..
P = MV is the equation for momentum...in order to get the mass a rearrange the equation
such that it looks like this: M = P/V now as an example let's suppose P = 10 and V = 10
So..for example I get M = 10/10
M = 1kg
Questions: What are the 'terms' for momentum and velocity in this equation?
Lets suppose for argument sake that I double the momentum so P = 20 & V =10.
I then come to a conclusion that I do not believe is accurate that if I increase the momentum of an object but not its velocity at the same time I have a decrease in mass ..in this case of 1/2 kilogram? Is that accurate?
Am I correct in assuming that if there is an increase in momentum there is a direct and corresponding increase in velocity?
Is it accurate to conlude that no matter what the increase in momentum there is NO increase in mass?
Thanks for any and all answers
Bye
But you have an increase in mass, m=20/10=2kg. Which is what you would expect.
16K
  • · Replies 19 ·
