What are the moment of inertia, angular speed, and angular kinetic energy?
  • Thread starter Thread starter gamer1319
    Physics
To find the moment of inertia of the electron in circular motion, the formula I = m*r^2 is used, where m is the mass of the electron and r is the radius of the orbit. Angular speed can be derived from the angular momentum equation L = I*W, allowing for the calculation of W once I is known. The angular kinetic energy is calculated using the formula KE = 0.5*I*W^2. The discussion emphasizes the need to first determine the speed of the electron to proceed with these calculations. Understanding these relationships is crucial for solving the problem effectively.
gamer1319
an electron (mass 9.11*10^-31kg) moves in a circular orbit around nucleus of mass 1.67*10^-27kg. if the radius of orbit is 5*10^-11 meters and the angular momentum is 1.05*10^-34 kg*m^2/s
find moment of inertia
angular speed
to find I, we need W (angular velocity). How do i find this if i just have 2 masses and radius?
well can you find speed of electron?
What's the moment of inertia of a point mass at a distance r from the center of rotation?
