Effective potential energy of a charge in a magnetic field
The discussion focuses on the effective potential energy of a charge moving in a magnetic field, specifically analyzing the force equation F_b = q v × B. When the magnetic field B is defined in the z direction, the force experienced by the charge is derived from its motion in cylindrical coordinates. According to John Taylor's "Classical Mechanics," the φ component of the force is zero, leading to the conclusion that the charge only experiences a radial force F_b = q ρ dot{φ} B hat{ρ}. This indicates that motion in the z direction does not contribute to the force in a magnetic field.
  • Understanding of Lagrangian mechanics
  • Familiarity with electromagnetic theory
  • Knowledge of cylindrical coordinates
  • Basic grasp of vector calculus
  • Study the Lagrangian formulation of electromagnetism
  • Explore the implications of the Lorentz force law
  • Learn about the motion of charged particles in magnetic fields
  • Investigate the role of potential energy in electromagnetic systems
Students and professionals in physics, particularly those studying electromagnetism and classical mechanics, as well as educators seeking to clarify concepts related to forces on charges in magnetic fields.
Ben Johnson
Hi,
I'm studying the Lagrangian and its applications in electromagnetism. I stumbled across this inconsistency:
The force of a charge moving through a magnetic field is
## F_b = q v \times B ##
If we define B to be in the ## \hat{z} ## direction, this equation can be written as
## F_b = q ( \dot{\rho} \hat{\rho} + \rho \dot{\phi} \hat{\phi} + z \hat{z} ) \times B \hat{z} ##
## F_b = q \dot{\rho} B (-\hat{\phi}) + q \rho \dot{\phi} B \hat{\rho} ##
## F_b = -q \dot{\rho} B \hat{\phi} + q \rho \dot{\phi} B \hat{\rho} ##
According to John Taylor (Classical Mechanics) the ## \hat{\phi} ## term is equal to zero and the only force the charge experiences is
## F_b = q \rho \dot{\phi} B \hat{\rho} ##
Why is this?
John who? I just looked up John Taylor and found this pdf...I am reading section 2.5 "Motion of a charge in a uniform magnetic field" and I don't see what you seem to indicate.
From the formulation shown (in Cartesian coordinates), the charge is going to experience two forces (one for each coordinate) and both are perpendicular to the direction of the magnetic field.
The same happens in cylindrical coordinates...if a charge moves purely in φ direction, it is going to experience a force that will push it radially out (increasing r); and if a charge moves in the radial direction r, it will experience a force that pushes it in the -φ. If the charge motion also has a z component, this will not produce a force...the magnetic field does not mind such motion as it is not crossing the field in anyway.
