Well, it could be, but ...
eigenfunctions have to be eigenfunctions of something. Namely, a matrix, or an operator (which is like a matrix, but often infinite-dimensional). They're mathematical entities which can represent physical entities. Your function could certainly be an eigenfunction of a mathematical operator, but it probably wouldn't be a physical eigenfunction. (Since this is the quantum physics forum I assume physical QM-related eigenfunctions are the main interest.)
Physical observables like momentum, position, energy are represented by operators in a Hilbert Space, and they have eigenfunctions - also called eigenvectors or eigenstates.
The thing is, normally k is used for a real number, and I assume it is here. The reason your function is unlikely to be a physical eigenfunction is that it blows up at negative infinity (supposing k is positive). If your function were only defined on the positive real number axis it could be a physical eigenfunction, because it goes to 0 and is square integrable.
In fact it can appear in tunneling problems; is that where you got it?
More likely you're probably missing an "i": it should be exp(-ikx). If k is square root (2mE) / hbar, for instance, then this could be a typical eigenfunction for the energy of a free particle (non-relativistic, time-independent).
