Eigenpairs and Hermitian matrices
  • Thread starter Thread starter Somefantastik
    Hermitian Matrices
Somefantastik
Choose [tex]\lambda_{1}, \lambda_{2}, \lambda_{3}[/tex] along with a set of vectors [tex]{v_{1},v_{2},v_{3}}[/tex] and construct an Hermitian matrix H with the eigenpairs [tex](\lambda_{1},v_{1}),(\lambda_{2},v_{2}),(\lambda_{3},v_{3})[/tex]
[tex]\lambda_{1} = 2[/tex]
[tex]\lambda_{2} = -2[/tex]
[tex]v_{1} = \widehat{i}+2\widehat{j}[/tex]
[tex]v_{2} = \widehat{i}-2\widehat{j}[/tex]
[tex]u_{1} = \frac{1}{\sqrt{5}}\left(\widehat{i} + 2\widehat{j} \right)[/tex]
[tex]u_{2} = \frac{1}{\sqrt{5}}\left(\widehat{i} - 2\widehat{j}\right)[/tex]
[tex]v_{3} = u_{1} \times u_{2} = -\frac{4}{5}\widehat{k}[/tex]
[tex]u_{3} = -\widehat{k}[/tex]
[tex]Basis: \ U = \left\{ u_{1},u_{2},u_{3} \right}\}[/tex]
[tex]H = \left| \begin{array}{ccc} 2 & 0 & 0 \\ 0 & -2 & 0 \\ 0 & 0 & 1 \end{array} \right|[/tex]
How does this look?
can you choose any values here?
why not just
[tex]\lambda_{1} = 1[/tex]
[tex]\lambda_{2} = 2[/tex]
[tex]\lambda_{3} = 3[/tex]
and
[tex]u_{1} = (1,0,0)[/tex]
[tex]u_{2} = (0,1,0)[/tex]
[tex]u_{3} = (0,0,1)[/tex]
then
[tex]H = \left| \begin{array}{ccc} 1 & 0 & 0 \\ 0 & 2& 0 \\ 0 & 0 & 3 \end{array} \right|[/tex]
If that's all this is, am I misunderstanding or is this a really trivial question?
maybe it asking if you are given arbitrary
[tex]u_1, u_2, u_3[/tex]
and corresponding eigenvalues
[tex]\lambda_1, \lambda_2, \lambda_3[/tex]
can you find a hermitian matrix H, with the given eigenpairs?
one way you could do is assume you have found H and it can be diagonalised (which you know it can, from the eigenvectors), then the diagonal form of H is
[tex]D = P^{-1}.H.P[/tex]
where
[tex]D = \left| \begin{array}{ccc} \lambda_1 & 0 & 0 \\ 0 & \lambda_2& 0 \\ 0 & 0 & \lambda_3 \end{array} \right|[/tex]
now the matrix P is simply given by the eigenvectors
where
[tex]P = \left| \begin{array}{ccc} u_1, u_2, u_3 \end{array} \right|[/tex]
then H is
[tex]H = PDP^{-1}[/tex]
that gives the eigenpairs, however I doubt it would automatically be hermitian... for that you need, where the star means conjugate transpose
[tex]H = H^*[/tex]
so running that through
[tex]PDP^{-1} = (PDP^{-1})^* = P^{-1}^*D^*P^* = P^{-1}^*DP^*[/tex]
hmmm... not totally sure where to go now
maybe a little left & right muliplication
[tex]D = P^{-1}(PDP^{-1})P = (P^{-1}P^{-1}^*)D(P^*P)[/tex]
this will be satisfied if P is unitary
[tex]P^*P = PP^* = I[/tex]
from before P is given by the eigenvectors (choose up to some multiplicative constant)
so in subscript form if j is the eigenvector and i is it's component, write
[tex]P = P_{ij} = u_{j}^{(i)}[/tex]
now for the transpose conjugate of a matrix
[tex]P^* = (P^*)_{ij} = \bar{P}_{ji} = \bar{u}_{i}^{(j)}[/tex]
matrix multipication is given by (with summation over the repeated indice)
[tex]P^*P = (P^*)_{ij}P_{jk} = \bar{u}_{i}^{(j)} u_{k}^{(j)}[/tex]
which looks just like a complex inner product between eigenvectors
so to satisfy the unitary condition we were looking for
[tex]PP^* = I \rightarrow \bar{u}_{i}^{(j)} u_{k}^{(j)} = \delta_{ik}[/tex]
ie. all the columns of P must form an orthonormal basis, which is a property of unitary matricies in general. So the condition will be satisfied if you just normalise your eigenvectors to length 1.
got a bit carried away there... but from this you should be able to write the general form of H no worries
Ok that helps. I guess I got confused and thought he was looking for D, but I think you're right; I think he's looking for PDP-1
Thanks!
