Eigenvalues of a 5x5 Matrix, continued
  • Thread starter Thread starter gabriels-horn
    Eigenvalues Matrix
29 replies · 7K views · last reply
gabriels-horn
The https://www.physicsforums.com/showthread.php?t=403476" was to determine the eigenvalues of the following matrix. View attachment 25800
The problem of interest deals with actually finding a solution to the system above without the use of matrix methods.
Printed textbook problem 50: Consider the 5 x 5 matrix given in Problem 31. Solve the system X' = AX without the aid of matrix methods, but write the general solution using matrix notation, then discuss how matrix methods of this section could solve it.
The template was to use the following system to solve this problem.
[tex]X\prime = AX =>\begin{bmatrix}x_1\prime \\x_2\prime \\x_3\prime \\x_4\prime \\x_5\prime\end{bmatrix}=\begin{bmatrix}2 & 1 & 0 & 0 & 0 \\ 0 & 2 & 0 & 0 & 0 \\ 0 & 0 & 2 & 0 & 0 \\ 0 & 0 & 0 & 2 & 1 \\ 0 & 0 & 0 & 0 & 2\end{bmatrix}\begin{bmatrix}x_1\\x_2\\x_3\\x_4\\x_5\end{bmatrix}[/tex]
So multiplying the matrix yields the following.
[tex]x_1\prime = 2x_1 + x_2[/tex]
[tex]x_2\prime = 2x_2[/tex]
[tex]x_3\prime = 2x_3[/tex]
[tex]x_4\prime = 2x_4 +x_5[/tex]
[tex]x_5\prime = 2x_5[/tex]
It was suggested that [tex]x_2[/tex] and [tex]x_5[/tex] be eliminated to solve this system. Any pointers on how to best do that? Can you separate the variables? For example, [tex]x_5\prime = 2x_5[/tex] is separated to
[tex]\int dy = \int 2x_5 dx_5[/tex]
and becomes [tex]y = x_5^2[/tex]
The problem of interest deals with actually finding a solution to the matrix above without the use of matrix methods. https://www.physicsforums.com/attachments/25838
The hint given was to use the following system to solve this problem.
[tex]\begin{bmatrix}x_1\prime \\x_2\prime \\x_3\prime \\x_4\prime \\x_5\prime\end{bmatrix}=\begin{bmatrix}2 & 1 & 0 & 0 & 0 \\ 0 & 2 & 0 & 0 & 0 \\ 0 & 0 & 2 & 0 & 0 \\ 0 & 0 & 0 & 2 & 1 \\ 0 & 0 & 0 & 0 & 2\end{bmatrix}\begin{bmatrix}x_1\\x_2\\x_3\\x_4\\x_5\end{bmatrix}[/tex]
No it doesn't. The differential equation you solved here does not involve y. It involved a dependent variable, x5, and an independent variable that is not shown, that I will call t.
There is a big difference between these two differential equations:
y' = 2x (solution y = x2 + C)
x' = 2x (solution x = Ae2t)
@Mark: why would you quote the whole message, especially if you're the first who replies?
@gabriels-horn: I have no idea what the exercise is. What is "a solution to the matrix"?
I rephrased to "a solution to the system" instead. I noticed the attachment was not working but I uploaded it again and it seems to be working fine.
This is the recommended policy on this forum. Occasionally a poster will go back and edit the initial post or even delete its content. Quoting the whole message ensures that there is a record of the initial post.
Agreed. I mixed up the variables before and changed y to t for convention. So separating the equation [tex]\frac{dx_5}{dt} = 2x_5[/tex] yields
[tex]\int 2dt=\int \frac{dx_5}{x_5}[/tex]
which simplifies to [tex]x_5=e^2^t[/tex]
My question is how to proceed from this point to solve the system.
Indeed, although don't forget the arbitrary constant. Your solution might be a class of functions (which would constitute the general solution). You should likewise solve for all the variables that are in a differential equation by themselves and then substitute.
Mark44 said:
It actually becomes x5 = Ae2t. Do the same for x2, and then you'll have a system of three DEs in three unknowns.
Solving for [tex]x_2[/tex] and [tex]x_5[/tex] and plugging them in yields the new system
[tex]x_1\prime = 2x_1 + C_1e^2^t[/tex]
[tex]x_4\prime = 2x_4 +C_2e^2^t[/tex]
I changed A to C since A has been used already. Any tips on how to proceed from here without using matrix methods as the problem says?
The constants should be different, say C1 and C2. In the remaining differential equations, two are nonhomogeneous and one is homogeneous. Each equation involves only one dependent variable, so they should all be fairly easy to solve.
Solving the system yields the following solutions,
[tex]x_1 = c_1te^2^t[/tex]
[tex]x_3 = c_2e^2^t[/tex]
[tex]x_4 = c_3te^2^t[/tex]
which is starting to look like the general solution that I need in matrix form, i.e.
[tex]X_G = c_1\begin{bmatrix}x_1\\x_2\\x_3\\x_4\\x_5\end{bmatrix}te^2^t+c_2\begin{bmatrix}x_1\\x_2\\x_3\\x_4\\x_5\end{bmatrix}2e^2^t+c_3\begin{bmatrix}x_1\\x_2\\x_3\\x_4\\x_5\end{bmatrix}te^2^t[/tex]
Does this look right? By using this method, how do you fill the entries for the matrices?
[tex]c_1\begin{bmatrix}y\end{bmatrix}\begin{bmatrix}te^2^t+c_2\begin{bmatrix}y\end{bmatrix}2e^2^t+\begin{bmatrix}y\begin{bmatrix}?\end{bmatrix}te^2^t[/tex]
The LaTeX above is screwed up.
Don't forget to put in x2 and x5. You can always check you solution by verifying that <x1', x2', x3', x4', x5'>T = A<x1, x2, x3, x4, x5>T.
Corrected as above.
Your solutions for x1 and x4 aren't complete. Those are just the particular solutions; they're missing the homogeneous part of the general solution.
These (above) are not right. Go back to post #9 and solve those three DEs. Also, you need to include x_2 and x_5.
This isn't right either. There should be no x on the right side. After all, you're trying to show what x (the vector) is in terms of the independent variable t.
I solved [tex]x_1\prime = 2x_1 + C_1e^2^t[/tex] by rearranging to
[tex]x_1\prime - 2x_1 = C_1e^2^t[/tex]
Finding [tex]p(t) = -2[/tex] and [tex]h(t) = e^2^t[/tex] allowed me to solve for [tex]\mu(t)[/tex], which gave the above solution. I tacked on the constant at the end to appear more like the usual solutions do for systems of linear ODE's.
Sorry for the confusion as to putting x's in the general solution above, they were meant to be constant entries and in no way related to the x values that I solved for earlier.
Well, you're making mistakes somewhere because the solutions you came up with aren't complete solutions. It sounds like you're using the integrating factor approach, which if you apply it correctly, should yield the complete solution. Show us your calculations.
But if x1' - 2x1 = c1e2t, the general solution is NOT x1(t) = Cte2t, which is what you have. There is another term. The same is true for x4.
You're right, I ignored the second term. Here is the work,
[tex]\mu(t) = e^\int^p^(^t^)^d^t \to e^-^2^t[/tex] which gets put into the integrating factor equation, yielding
[tex]\mu(t)=\frac{\int e^-^2^t e^2^tdt+ C}{e^-^2^t}[/tex] which simplifies to
[tex]\mu(t)=te^2^t + Ce^2^t[/tex]
Mark44 said:
So, what do you have now for x_1(t), x_2(t), ... , x_5(t)?
The system becomes after combining the constants,
[tex]x_1 = c_1(t+1)e^2^t[/tex]
[tex]x_2 = c_2e^2^t[/tex]
[tex]x_3 = c_3e^2^t[/tex]
[tex]x_4 = c_4(t+1)e^2^t[/tex]
[tex]x_5 = c_5e^2^t[/tex]
Don't forget to keep track of the arbitrary constants. You should have
[tex]x_1(t) = C_1 te^{2t} + Ce^{2t}[/tex]
where C1 is the constant that appears in x2.
EDIT: I see you posted while I was typing. You can't combine the constants the way you did.
Mark44 said:
For the third time, where are x_2 and x_5? I'll hold off commenting on your general solution.
I guess you read that post before I was able to put them in. I think I'm bogging down the server with all of the LaTeX commands. The general solution should be
[tex]X_G = c_1\begin{bmatrix}a_1\\a_2\\a_3\\a_4\\a_5\end{bmatrix}(t+1)e^2^t+c_2\begin{bmatrix}b_1\\b_2\\b_3\\b_4\\b_5\end{bmatrix}e^2^t+c_3\begin{bmatrix}d_1\\d_2\\d_3\\d_4\\d_5\end{bmatrix}e^2^t+c_4\begin{bmatrix}e_1\\e_2\\e_3\\e_4\\e_5\end{bmatrix}(t+1)e^2^t+c_5\begin{bmatrix}f_1\\f_2\\f_3\\f_4\\f_5\end{bmatrix}e^2^t[/tex]
Anyone care to enlighten me as to the correct form of the general solution?
Your expression
is equivalent to
[tex]x_1 = c_1 a_1 (t+1)e^{2t}+c_2 b_1 e^{2t} + c_3 d_1 e^{2t} + c_4 e_1 (t+1)e^{2t} + c_5 f_1 e^{2t}[/tex]
and so on. What values of a1, b1, d1, e1, and f1 you need so it matches what your solution for x1?
But first, you need to fix your expressions for x1 and x4, which will in turn require you to rewrite XG slightly.
vela said:
Your expression
is equivalent to
The problem just asked to write the general solution with matrices, but I got the feeling that the matrices for the system I wrote were incorrect. Maybe my notation is incorrect. I used a, b, d, e and f to represent the actual entries that will go into them. I don't necessarily know what those are, but they were alluded to in the previous thread related to this one. Thanks for the help with this one.
You should be able to determine the values of a, b, d, e, and f by inspection once you have the solution.
Here's a simpler example. Suppose you had a 2x2 system with the solution
[tex]\begin{align*}<br /> x_1 &= c_1 te^t + c_2e^{2t} \\<br /> x_2 &= c_2 e^{2t}<br /> \end{align*}[/tex]
You can write that as
[tex]\begin{pmatrix}x_1\\x_2\end{pmatrix} = c_1\begin{pmatrix}te^t\\0\end{pmatrix}+c_2\begin{pmatrix}e^{2t}\\e^{2t}\end{pmatrix}=\begin{pmatrix}te^t & e^{2t} \\ 0 & e^{2t}\end{pmatrix}\begin{pmatrix}c_1\\c_2\end{pmatrix}[/tex]
