Eigenvalues of a "unusual" Hamiltonian of a harmonic oscillator
  • Thread starter Thread starter laser1
The discussion revolves around the eigenvalues of an unusual Hamiltonian related to a harmonic oscillator, specifically focusing on the properties of a self-adjoint operator and its implications on the eigenstates and eigenvalues of the associated number operator.
  • Participants explore the implications of the commutation relations for the operators involved, questioning the nature of the eigenvalues and the validity of certain assumptions regarding the eigenstates.
Some participants have provided insights into the commutation relations and their effects on the eigenvalues, while others are questioning the assumptions made about the self-adjoint nature of the operator and the resulting eigenstates. Multiple interpretations of the eigenvalue structure are being explored without a clear consensus.
There is an ongoing discussion about the implications of the unusual commutation relation and the constraints it imposes on the eigenvalues, with some participants noting the potential for ambiguity in the problem setup.
laser1
Description
N/A
for d), I am a bit confused. I have two trains of thoughts here
any thoughts on which answer is correct, and why the other one is incorrect? Both seem like valid solutions to me. Or is the question ambiguous?
thanks
Please use LaTeX. I can't quote images, and also...
Given that ##~\hat{b}~## is a self-adjoint operator and ##~\hat{b}^\dagger~## is its adjoint, I'd expect their commutator to vanish. What am I missing?
I'd say some more if your question will become quotable. For now, note that the Hilbert space must be closed: if ##~|\phi\rangle~## is a state, so is ##~b|\phi\rangle~##.
Let us consider the following Hamiltonian
\hat{H}=\hbar\omega\left(\hat{b}^\dagger \hat{b}+\frac{1}{2}\right).
The self-adjoint operator ##\hat b## and its adjoint ##\hat b^\dagger## fulfil the (unusual) commutation relation
[\hat b,\hat b^\dagger]=\hat b\hat b^\dagger-\hat b^\dagger\hat b = 4.
Define an (unusual) number operator by ##\hat N=\hat b^\dagger \hat b##. The normalised eigenstates of ##\hat N## are ##|\phi_n\rangle## such that
\hat N|\phi_n\rangle = n|\phi_n\rangle.
(a) Evaluate the commutator ##[\hat b,\hat N]##.
(b) Use the previous result to show that ##\hat b|\phi_n\rangle## is a (not-normalised) eigenstate of the number operator for ##n\ge 4##. What is the corresponding eigenvalue?
(c) Let ##|\Phi\rangle=g\,\hat b|\phi_n\rangle## with ##g\in\mathbb R##. Calculate the value of ##g\ge 0## such that ##\|\Phi\|=1##.
(d) Use the previous results to argue what are the eigenvalues of this unusual number operator ##\hat N##.
My working so far:
(a) I evaluated the commutator and found
[\hat b,\hat N]=4\hat b.
(b) I deduced that
\hat N\hat b=\hat b\hat N-4\hat b,
so that ##\hat b|\phi_n\rangle## is an eigenstate with eigenvalue ##n-4##.
(c) Using the norm condition, I got ##g=1/\sqrt{n}##.
For (d), I am confused. I have two trains of thought:
(1) The smallest eigenvalue is ##0## because repeatedly applying ##\hat b## will keep lowering the eigenvalue until it would become negative, which contradicts the property that the eigenvalue must satisfy ##n\ge 0## (since ##\langle\psi|\hat N|\psi\rangle=\|\hat b|\psi\rangle\|^2\ge 0##). So then the only possible eigenvalues are ##0,4,8,\dots##.
(2) Since part (b) is only stated for ##n\ge 4##, I can start from e.g. ##7## and then stop when it hits ##3##, because the relation doesn't apply again. So then the solutions also include ##3,7,11,\dots##. The same logic can be applied to ##1,5,9,\dots## and ##2,6,10,\dots##, which would suggest the eigenvalues are ##0,1,2,3,\dots##.
Any thoughts on which answer is correct, and why the other one is incorrect? Both seem valid to me, or is the question ambiguous?
JimWhoKnew said:
Given that b^ is a self-adjoint operator and b^† is its adjoint, I'd expect their commutator to vanish. What am I missing?
you are correct, I asked my professor, he said it is an error, ##\hat{b}## is not self-adjoint.
Why not?
In (b) you were asked about ##~n\ge 4~##, but the commutation relations are valid throughout, so your answer to (b) should apply to any participating ##n~## (edit: ##~\hat{b}|\phi_0\rangle~## is an exception). Suppose ##~|\phi_7\rangle~## exists. Then ##~\hat{N}\hat{b}|\phi_7\rangle=3\hat{b}|\phi_7\rangle~##. But then ##~\hat{b}\hat{b}|\phi_7\rangle~## is also a state. Is it an eigenstate of ##~\hat{N}~##?
BTW: since it had taken you such a short time to re-post in LaTeX, why didn't you just do so in #1?
JimWhoKnew said:
Why not?
hmm yes good point, the relations are valid throughout. So ##|\phi_7\rangle## exists, so ##|\phi_3\rangle## exists, which means ##|\phi_{-1}\rangle## exists, which can't be possible, so that whole ladder can't exist?
This "unusual" HO follows from the "usual" by substituting ##~\hat{a}=\hat{b}/2~## and identifying ##~|\phi_n^{(a)}\rangle~## as ##~|\phi_{4n}^{(b)}\rangle~##. Compare the energy spectra.
so it is only 0, 4, 8, ...?
Yes, by the argument you wrote in #5.
