How Do Eigenvalues and Eigenvectors Change for Matrix B = exp(3A) + 5I?
The eigenvalues of the matrix B = exp(3A) + 5I can be determined from the eigenvalues of matrix A. The eigenvalues of exp(3A) are e^(3λ), where λ are the eigenvalues of A. Therefore, the eigenvalues of B are e^(3λ) + 5. The eigenvectors of B remain the same as those of A. This method allows for the calculation of eigenvalues and eigenvectors for the transformed matrix B.
Physgeek64
Find the eigenvalues and eigenvectors of the matrix
##A=\matrix{{2, 0, -1}\\{0, 2, -1}\\{-1, -1, 3} }##
What are the eigenvalues and eigenvectors of the matrix B = exp(3A) + 5I, where I is
the identity matrix?
So I've found the eigenvectors for A to be ##\frac{1}{\sqrt{6}}\vec{1,1,-2}##, ##\frac{1}{\sqrt{3}}\vec{1,1,1}##, ##\frac{1}{\sqrt{2}}\vec{-1,1,0}## with eigenvalues 4,1 one 2 respectively. but i don't know how to do the second part
Many thanks
Can you calculate the eigenvalues of ##exp(A)##?
They are the exponentials of the eigenvalues of A
Well, that's a good start. What about ##exp(3A)##?
##e^{3\lambda}##?
Physgeek64 said:
##e^{3\lambda}##?
How could you prove that if you are not sure? Hint: it's not hard. Try letting ##B = 3A##
the eigenvalues of ##exp(B)## are ##e^b## but ##b=3a## where a are the eigenvalues of A for ##B=3A##. Hence the eigenvalues are ##e^{3a}##
Yes. Although, I would start with something like:
Let ##v## be an eigenvector of ##A## with eigenvalue ##\lambda \dots##
Okay. But how do you find the eigenvalues of ##exp(3A)+5I##?
I thought you had worked it out. Where do you think you are stuck?
##\dots Bv = (\exp(3A) + 5I)v = \dots##
Does that help?
Many thanks
For future reference: you can format a matrix nicely as
$$A = \pmatrix{2 & 0 & -1\\0 & 2 & -1 \\ -1 & -1 & 3}$$
The instructions that do that are "\pmatrix{2 & 0 & -1\\0 & 2 & -1 \\ -1 & -1 & 3}". Note the use of '&' as a separator, not a comma, and there is only one pair of curly brackets "{ }".
Also, your eigenvalues read as ##\langle \frac{1}{\sqrt{6}} 1 , 1, -2 \rangle##, but you might have meant ##\frac{1}{\sqrt{6}} \langle 1,1,-2 \rangle##, which is very different. Using ##\vec{\mbox{ }}## does not work well for an array of more than about two characters in length, so ##\vec{v_1}## looks OK but ##\vec{v_1, v_2, v_3,v_4}## does not.
Likes Marc Rindermann
Does that help?
Will have eigenvalues ##e^{3a+5}## with the same eigenvectors
Thank you for your help
Is that ##exp(3a+5)## or ##exp(3a) + 5##?
Oops sorry its meant to be ##exp(3a) + 5##
  • · Replies 33 ·
  • · Replies 18 ·
