Einstein and his theory of light speed
Einstein's theory posits that no massive object can reach or exceed the speed of light due to the requirement of infinite energy for acceleration to that speed. Even in a vacuum, where friction is absent, the laws of physics dictate that massive particles cannot achieve light speed. The concept of timelike four-momentum further explains that massive particles are bound to velocities less than light speed. Discussions also clarify that friction is not a factor in this context; rather, it is mass and inertia that resist acceleration. Understanding these principles is essential for grasping the limitations imposed by special relativity.
kimster
Einstein theorized that if you were to go the speed of light or even faster then the light around you would become paralyzed. But if you're going that fast then the light wouldn't be able to catch up to you, so technically wouldn't the light around you would become black because the light cannot catch up to you.
No massive object can travel at any speed equal or greater than the speed of light.
actually it can, what would be preventing it form going that fast? space has no friction or air friction to prevent an object form exceeding that speed
There are a couple of things. The first is that it would require an infinite amount of energy to accelerate a massive object to c. So that prevents an object from reaching c from any v<c. This has been verified in particle accelerators on a daily basis. No matter how much energy we pump into a particle it still remains at some v<c.
The second is a little more technical, but explains why a massive particle cannot simply start out at v>c. A massive particle has a timelike four-momentum by definition, and a timelike four-momentum implies a timelike four-velocity. All timelike four-velocities correspond to v<c.
MODERATOR'S NOTE:
Several posts in this thread have been deleted. Please keep the discussion factual, courteous, and helpful.
This is wronger than just as pertains to special relativity: friction has nothing to do with anything. It is mass (inertia) that resists acceleration via f=ma.
  • · Replies 18 ·
  • · Replies 34 ·
  • · Replies 21 ·
  • · Replies 45 ·
  • · Replies 22 ·
