Elastic collision between pendulum bobs with different masses
XwakeriderX
(see attachment)
The work the did gives the correct answer but i do not understand where a lot of that stuff came from! My first question about the work is how they derived 1/2[(m_1)((v_i)_1)^2] =m_1gh
Below is the solution
length of the string l =1.5 m
angle =25 degrees
height h_1 =h_2 =h =l(1-cosθ) =0.14 m
mass of the left side sphere m_1 =100 gm =0.1 kg
mass of the right side sphere m_2 =50 gm =0.05 kg
when left side ball is at height h (mass m_1) ,apply conservation of mechanical energy ,we get
velocity of the left side ball (v_i)_1,just before the collision (v_i)_1=sq.root (2gh) =1.657 m/s
after the collision:
b)
(v_f)_1 =[m_1-m_2/m_1+m_2](v_i)_1
substitute the given data in above equation we get,
velocity of the left side ball after the collision =(v_f)_1 =0.552 m/s
(v_f)_2 =[(2m_1)/m_1+m_2](v_i)_1
velocity of the right side ball after the collision =(v_f)_2 =2.21 m/s
c)
after the collision ,the height of m_1 is
( h_f)_1 =l(1-cosθ) =[[(v_f)_1]^2]/2g
(1-cosθ) =[[(v_f)_1]^2]/2gl
cosθ =1-[[(v_f)_1]^2]/2gl
maximum angle for left side ball ,θ =8.26 deg≈ 8.28 deg
after the collision ,the height of m_2 is
( h_f)_2 =[[(v_f)_2]^2]/2g
cosθ =1-[[(v_f)_2]^2]/2gl
maximum angle for right side ball ,θ =42.25 deg≈ 42.3 deg
How about instead of worrying about how someone else solved the problem, you start from first principles yourself to solve the problem? In sequence:
1. What is the energy of each ball just before they're released?
2. What is the energy of each ball just before they collide?
3. What is the momentum of each ball just before they collide?
4. What is the total momentum of the system before they collide? (express as a formula)
5. What is the total momentum of the system after they collide? (express as a formula)
6. What is the total energy of the system after they collide?
7. What is the momentum and energy of each ball just after they collide?
8. What is the energy of each ball when they are at the top of the swing after the collison?
By finding expressions for everything in order and applying the conservation laws, you will determine the angles for which you are asked.
