Elastic potential energy problem needs to be checked
5 replies · 2K views
phys1618
a force of 2.0 N is needed to push a .1k jack in the vox into its box, an operation in whihc the spring is compressed .1 m. what will be eh maximum speed of the jack in the box when it comes out?
k=f/x
T=2pi(sq.root(m/k)
Vmax=(2piA)/T
I took the force and used k=f/x eq. and have 20N/m for the force constant which was k.
then i used the T equation and have .4442882938s.
then i used the vmax eq. with the answer from T to get 1.414 m/s as the max. velocity
did i do it right or have made a mistake somewhere?
thank you in advance
Seems good to me. You could have avoided the SHM equations by setting the work done in compressing the spring = the maximum possible kinetic energy of the mass. You'd get the same answer with either method, which is always a good way to check your calculations.
thank you for your response...
however is there a big difference between this problem and my other problem?(https://www.physicsforums.com/showthread.php?t=290599)
because for this i didnt have to multiply the T by 1/4 but the other one i do?
I'm just trying to understand more between the problems and actually know when to use 1/4 and when not to?
thank you for all your help!
In the other problem you wanted to find the time taken for the spring to compress the full 4m. You did this by thinking about the mass and the spring doing simple harmonic motion. You have a formula T = 2 * pi * [tex]\sqrt{\frac{m}{k}}[/tex] which gives the period of the oscillations that the mass would do if it was attached to the spring and left to osscillate. The period is the time taken for the mass to move from the equlibrium position (the position where the spring is neither streched or compressed) to it's maxium displacement in one direction, back through the equilibrium position to the maximum displacement in the other direction and then back to the equilibrium position again. This is one osscillation.
To find the time taken to move from the equilibrium position to the maximum displacement (4 m in this case) you simply realize that this is 1/4 of a complete oscillation and therefore takes 1/4 of the period.
In the second problem you wanted the maximum velocity of the mass and the formula that you were using involved the time period of the system and the amplitude. In this case you could just find the period and sub it right on into your formula for Vmax.
On a more general point, both questions are very similar if you think about them in terms of the conservation of energy. In the first question the kinetic energy of the mass is being changed into elastic potential energy in the spring. In the second the elastic potential energy in the spring is being changed into kinetic energy in the mass. If you get a chance, sit back and ponder how applying the principle of conservation of energy could have been used with these problems.
I hope this is helpful.
so for the other problem...it only takes 1/4 of the actual T to fully compress the spring right?
That's right. The time taken for 1/4 of an oscillation is 1/4 T.
