Elastic Section Modulus vs Moment of Inertia
The discussion centers on the concepts of Elastic Section Modulus and Moment of Inertia within the context of Structural Engineering. Participants explore the definitions, applications, and differences between these two properties, particularly in relation to beam strength and resistance to bending.
  • One participant notes that Moment of Inertia relates to mass distribution and resistance to applied moment, while Elastic Section Modulus relates to area distribution and resistance to elastic deformation.
  • Another participant clarifies that the area moment of inertia is a property of shape and area distribution, distinct from mass moment of inertia, and emphasizes that bending stress is not dependent on the modulus of elasticity.
  • A participant discusses the relationship between mass moment of inertia and the dynamics of bodies in motion, contrasting it with the second moment of area used in structural analysis.
  • There is a suggestion that elastic modulus, being dependent on area distribution, quantifies resistance to bending similarly to the second moment of area.
  • One participant raises a question about the relationship between elastic modulus and the first moment of area, proposing a mathematical connection but acknowledging the need for clarification.
  • Another participant points out that while section modulus has the same units as the first moment of area, it should not be confused with it, suggesting further calculations could clarify this distinction.
Participants express differing views on the relationships between Elastic Section Modulus, Moment of Inertia, and elastic modulus, indicating that the discussion remains unresolved with multiple competing perspectives.
Participants highlight potential confusion between different types of moments of inertia and their applications, as well as the mathematical relationships among them, without reaching a consensus on these points.
Peter10
Hi everyone!
Please help, I have spent a considerable time to understand the two concepts and still this is nagging at me... I am relating to Structural Engineering, just to let you know guys. My question is ..
Moment of inertia is about distribution of mass, the further away from the axis the higher the resistance to applied moment ( I believe I know the concepts of angular acceleration and etc.). Likewise in case of Elastic Section Modulus if the distribution of area of section is larger away from the axis the resistance to elastic deformation is greater... So in terms of Structural Engineering what is the difference between the two? I know that moment of inertia is related to mass (althou it is in cm^4 which is brings another question, why is it not in kg?), but as in practical sense why do we need one or the other to determine the strength of the beam, let's say up to elastic limit?
You are looking for area moment of inertia in units of length^4 , not to be confused with the mass moment of inertia. Area moment of inertia is a property of the shape and area distribution. Bending stress My/I is not dependent on the E modulus. Bending strain is My/EI . You can have 2 similar beams of the same shape and length and loading etc but of different materials, and the bending stress will be the same in either case, but the bending strains and deflections will not. In regard to the elastic stress limit, that is not a function of either E or I.
Peter10 said:
Hi everyone!
You are confusing two different concepts, namely the second moment of area and the mass moment of inertia, which are unfortunately and inaccurately known by the grab-all term "moment of inertia".
Let's take the "mass moment of inertia" of a body first.
We know from Newton's laws of motion that it takes a certain applied effort to change the motion of a body. For bodies in rectilinear motion, the equation F = ma describes how the acceleration of a body of mass m will change when a certain external force F is applied.
For bodies in rotational motion, the corresponding equation is T = J α, where J is the mass moment of inertia of the body (and which has units of ML2) and α is the angular acceleration (units of radians per second2) produced by the applied torque T (units of force times distance, or M × L × T-2 × L = ML2T-2). The mass moment of inertia J is an intrinsic property of the body, the value of which is influenced by the distribution of mass about the center of gravity.
The mass moment of inertia is used to calculate the dynamics of bodies undergoing motion.
The other moment of inertia, the second moment of area, is the one which is most commonly encountered in structural engineering. The second moment of area, usually denoted as I, arises from studying the bending of beams. The bending stress σ in a beam is given by the equation σ = M y / I, where M is the applied bending moment, y is the distance from the neutral axis to where the bending stress is sought, and I is the second moment of area of the cross section of the beam. This inertia is roughly analogous to J in that it describes the distribution of section area about the centroid of the section. The units of I are A × L2 (compare the units of J = M × L2), which is why tables of structural properties have units like cm4.
In beam analysis, the maximum bending stress is encountered at the outer fiber of the beam, which is located at the greatest distance from the neutral axis.
Thus for a given structural section, I can be calculated and y is known from the geometry, so the bending stress formula can be re-written as σ = M / SM, where SM is the section modulus of the beam cross section and SM = I / y (units of L3. By knowing the section modulus of a beam at a given location, it is thus a simple calculation to find out how much bending moment will produce a given level of bending stress. If you take a beam with a limiting elastic stress σ, then the maximum bending moment is M = σ × SM.
Thank you guys for your explanations. I am aware of the fact that section modulus it for computing maximum stress within elastic limit. However
1. As elastic modulus is also dependent on the area distribution and distance from the neutral axis ,it quantifies the ' resistance' of the beam to bending just as second moment of area?
2. I read somewhere that elastic modulus is the same as first moment of area( well if Second Mom. of Area is A^2/y^2 and we divide it by y we get A^2/y,,, the same as first moment of area?
Stronger beams generally tend to have numerically greater second moments of area, since SM = I / y. More than anything, the SM is typically used to simplify the calculation of bending stress a little, or to compare the strength of two or more different beam cross sections.
Although the section modulus SM = I / y has the same units as the first moment of area, it should not be confused with being the same quantity as the first moment of area. Doing some simple calculations for various types of structural sections should confirm this.
Thank you!
  • · Replies 40 ·
  • · Replies 16 ·
