Electric field at a point from three equal positive charges
  • Thread starter Thread starter flyingpig
    Coulomb's law Law
46 replies · 7K views
flyingpig
[PLAIN]http://img547.imageshack.us/img547/7932/14207376.png
[PLAIN]http://img684.imageshack.us/img684/719/75458442.png
[PLAIN]http://img88.imageshack.us/img88/4883/55224430.png
Assume [tex]q_{1}=q_{2}=q_{3}[/tex] and that all charges are positive.
*if someone could, please tell me the proper code for vectors, because I am having trouble
For the first of the problem
[tex]\vec{E_{1}} = \vec{E_{21}}[/tex]
Since it sort of just "sits in space", I put q_{2} on the origin.
So [tex]\vec{E_{21}} = <0, k\frac{q_2}{d^2}>[/tex] and the magnitude should simply be [tex]k\frac{q_2}{d^2}[/tex].
For the second part
[tex]\vec{E_{1}} = \vec{E_{21}} + \vec{E_{31}}[/tex]
[tex]\vec{E_{31}} = k\frac{q_{3}}{d^2}<-\frac{\sqrt{2}}{2}, \frac{\sqrt{2}}{2}>[/tex]
Since [tex]\vec{E_{21}} = <0, k\frac{q_2}{d^2}>[/tex]
Then the sum would be [tex]\vec{E_{1}}= \frac{k}{d^2}<-q_{3}\frac{\sqrt{2}}{2}, q_{3}\frac{\sqrt{2}}{2} + q_{2}>[/tex]
hi flyingpig! :smile:
(it's easiest to use bold letters for vectors :wink:)
i] the field is kq/d2, but the force is kqq/d2
ii] i think you're using 45° for the angle, it's 60° :wink:
iii] don't forget the question says you can assume the qs are all the same!
Oh right...what am I doing!? I was reading "electrostatic" and it immediately turned into field.
But what if I want to use arrows? I actually find it more difficult to tell if it is bold.
[tex]\vec{F_{1}} = \vec{F_{21}}[/tex]
[tex]\vec{F_{21}}= k\frac{q^2}{d^2}<0,1>[/tex]
That's part one
For part two
[tex]\vec{F_{1}} = \vec{F_{21}} + \vec{F_{31}}[/tex]
[tex]\vec{F_{31}}= k\frac{q^2}{d^2}<-\frac{\sqrt{3}}{2}, \frac{1}{2}>[/tex]
So the sum of [tex]\vec{F_{21}} + \vec{F_{31}}[/tex] is then
[tex]k\frac{q^2}{d^2}<-\frac{\sqrt{3}}{2}, \frac{3}{2}>[/tex]
So now, my question is, should I turn this into a unit vector?
Try to be polite next time.
______________________________________________________
No, why would turn this into a unit vector?
Unit vector has mag of 1
it will mean that that your force also has a unit vector of one!
I wasn't being rude =(! Not sure where you caught that from.
But I thought the unit vector will only take care of the direction of my force, not the force itself? Is it okay to leave my answer above like that?
Did I get it right!??
Thanks!
Yes your answer is right.
And direction can still be founded with this result. unit vectors just provide direction without changing mag of something!
10(i) + 10(j) has same direction as its unit vector (1/√2)(i) + (1/√2)(j)
I noticed something, this problem just want to assume that I place q2 at the origin, why?
Also, I thought the concept of unit vector is like multiplying and dividing by one, does it really matter?
Well this problem doesnot depend on the choice of origin
Also, as long as orientation of XYZ is same direction will also remain same ... but mag of force always remain same no matter where is the origin
cupid.callin, whatever are you talking about? :frown:
flyingpig said:
… So now, my question is, should I turn this into a unit vector?
Sort of.
The question asks for "the magnitude and direction".
So you need to find the magnitude anyway …
once you've done that, what's left is the unit vector of the direction! :smile:
hmmm … not sure what you mean by either of those. :confused:
But I thought taking the unit vector according to cep will yield a magnitude of 1N
Sorry I wasn't sure what my question is now that I read over again.
Both unit vector and vector itself gives same direction.
If answer is written with mag <not original vector> then only you need to give unit vector, or even better just give answer in degrees!
If he's giving answer in original vector, why waste time in finding unit vector also?
now I'm really confused :redface:
you got kq2/x2 < -√3/2, 3/2 > …
where does 1N come into that? :confused:
you need to convert < -√3/2, 3/2 > to a magnitude times a unit vector :wink:
he he :biggrin:
you agree that unit vector of < -√3/2, 3/2 > will have mag of 1, right?
So by this you mean that net force is just kq2/x2
< -√3/2, 3/2 > has nothing to do in the mag?
he he :biggrin:
I got it from this
But once I get it to the unit vector, wouldn't my force be one like he said? Or is that actually not surprising since the distance is is d after all?
Which distance is d?
cupid.callin, are you drunk? :frown:
flyingpig, please ignore his advice.
express < -√3/2, 3/2 > as a magnitude times a unit vector, say M <a,b> where <a,b> is the unit vector
then the magnitude of the force is M times kq2/x2, and it is in the direction of <a,b> :smile:
We don't know! It could be anything and it shouldn't matter
Don't you mean 1/M?
[tex]k\frac{q^2}{\sqrt{3}{d^2}}<-\frac{\sqrt{3}}{2}, \frac{3}{2}>[/tex]
But then I would get back at [tex]k\frac{q^2}{d^2}[/tex]
(just got up :zzz: …)
no …
for example if the vector was 3 <4,0>,
that would be 12 <1,0> …
magnitude 12, in the direction of unit vector <1,0> :wink:
Then what am I thinking of? For 3<4,0>
M = 12
So 1/12<12,0>?
1/12 of <12,0> is the unit vector <1,0> …
are you thinking of a way to make unit vectors? :confused:
Isn't that the goal?
half the goal …
the goal (in the original question) was to find the magnitude and the direction …
ie a magnitude and a unit vector :smile:
tiny-tim said:
half the goal …
[tex]k\frac{q^2}{\sqrt{3}{d^2}}<-\frac{\sqrt{3}}{2}, \frac{3}{2}>[/tex] <=== Unit vector
[tex]k\frac{\sqrt{3}q^2}{d^2}[/tex] <=== magnitude.
<-√3/2, 3/2> is not a unit vector :confused:
But I had [tex]\sqrt{3}[/tex] in the denominator.
i don't understand …
are you saying that <-√3/2, 3/2> is a unit vector? :confused:
No, but 1/√3<-√3/2,3/2> is
yeeees … why not just write it < -1/2, √3/2 > ? :confused:
(btw, you could have seen, just by looking at the original diagram, that the angle was going to be 30° :wink:)
That's what I had here
But when I take the magnitude, it will be one, not √3 of the force.
