Electric field inside a uniformly charged insulator
9 replies · 33K views · last reply
0blivi0n
ok here's the problem: find the magnitude of the electric field inside uniformly charged insulating sphere of raduis R.
application of gauss's law..but...
should i use
[tex]\phi[/tex] = q[tex]_{encl}\epsilon_0[/tex]
or
[tex]\phi[/tex] = q[tex]_{encl}[/tex]/[tex]\kappa[/tex][tex]\epsilon[/tex]
It becomes slightly different inside a sphere. Electric fields are vectors, and a point inside a sphere is being affected by an electric field in every direction. Heres what you need to know: Any point inside a spherical shell of any thickness receives a net electric field of 0N/C. Same concept applies to electric force and gravity.
Here is a site to help you out on this:
http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/elesph.html
Using that, if a point is a radial distance a from the center of the sphere (while inside the sphere), the net electric field at a point inside a sphere would be due to only the the charge within the radial distance (the charges outside the radial distance contributes to the 0N/C).
So, are you in space or a material? Would you want to use the electric constant for free space or not?
that is what I'm confuswed about...if the insulating sphere is made of a material other than air, which one should I use on the righthand side of the flux equation? [tex]\epsilon_{0}[/tex] or [tex]\epsilon[/tex]. that is should I take the permittivity constant ([tex]\kappa[/tex]) into account or not?
Since you are solving for the electric field strength E, you would just use [tex]\epsilon_{o}[/tex]. If you were asked for the electric flux density D, you would need to be concerned with the electric permittivity of the material. (The hint is that you aren't given a value for [tex]\kappa[/tex] in the problem...)
0blivi0n said:
should i use
or
Out of curiosity, what volume are you using for the enclosed charge?
thanks dynamicsolo. I'm starting to see how things are now
0blivi0n said:
a sphere
thats a shape, not a volume
If a charge were distributed uniformly on the surface of the balloon(insulator). A point particle with charge q inside is greatest when it is anywhere inside the sphere because the force is zero?
or when it is near the inside surface of the balloon?
