Why Does Integration Differ Between Electric Fields of a Disk and a Line Charge?
The discussion centers on the integration of electric fields from different charge distributions, specifically comparing a ring charge and a line charge. The user derived the electric field expression for a ring as E = KxΔq/(R² + x²)^(3/2) and noted that the book's final expression was E = Kxq/(R² + x²)^(3/2). The confusion arose from the integration with respect to Δq for the ring charge, while for the line charge, ΔQ was replaced with ΔQ = Q/L Δy due to its geometric properties. The discussion clarifies that for a ring, the surface charge density σ allows for direct integration, unlike the line charge scenario.
  • Understanding of electric field equations, specifically E = Kq/r²
  • Familiarity with charge distributions, including linear and surface charge densities
  • Knowledge of calculus, particularly integration techniques
  • Basic concepts of electrostatics and field theory
  • Study the derivation of electric fields from different charge distributions, focusing on surface charge density
  • Learn about the application of Gauss's Law in calculating electric fields
  • Explore the differences in integration techniques for line charges versus surface charges
  • Investigate the geometric interpretations of charge distributions in electrostatics
Students of physics, particularly those studying electromagnetism, educators explaining electric field concepts, and anyone seeking clarity on charge distribution integration methods.
tuggler
I am suppose to find an expression for the electric field of a ring.
E =\frac{Kq}{r^2}
I calculated my results and I reached up to this:
\frac{Kx\Delta q}{(R^2 + x^2)}^{3/2} where R = radius, x = distance, K = constant, q = charge.
And then I looked at my book and noticed they integrated with respect to \Delta q which got me confused because when I calculated the electric field due to a line charge \Delta q it wasn't considered a geometric property. The final expression the book gave \frac{Kx q}{(R^2 + x^2)}^{3/2}.
How come they can integrate with respect to \Delta q in this case but not a line charge?
For example, when I was measuring the electric field of a line of charge I got the expression \sum \frac{d \Delta Q}{(y_1^2 + d^2)^{3/2}} but with that expression I couldn't integrate over \Delta Q because the book said it is not a geometric quantity so I had to replace \Delta Q with \Delta Q = Q/L \Delta y. I don't understand why we had to change it with the field of a line but not with a disk?
The book did the same thing with an electric field of a ring as they did with the line of charge by replacing \Delta Q with the density over the surface area 2r\pi dr.
I suppose you talk about a disk ( on your first statement you talk about "ring"). For the ring you have the field of a line so you multiply your linear density with λdx = λrdθ. Now you have a surface with density σ. So dq = σda = σ(2πrdr).
Draw a diagram and you will see the validity of that. look the area that represents 2πrdr
