Electric Field of a Non-Uniformly Charged Sphere | Homework Help
The discussion centers on calculating the electric field of a non-uniformly charged sphere, where the charge density is defined as ρ = Ar². The electric field outside the sphere is derived as E = (AR⁵)/(5ε₀r²), while the electric field inside is E = (AR³)/(5ε₀). Participants emphasize the application of Gauss's law and the importance of correctly setting up integrals to find the total charge Q from the charge density.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with charge density concepts
  • Ability to perform calculus integrals
  • Knowledge of spherical symmetry in electric fields
  • Study the application of Gauss's Law for spherically symmetric charge distributions
  • Learn to set up and solve integrals for charge density functions
  • Explore the derivation of electric fields from charge distributions
  • Review the concept of electric field lines and their relation to charge density
Students studying electromagnetism, physics educators, and anyone seeking to understand electric fields generated by non-uniform charge distributions.
Dgeld
A solid isolated sphere with radius R has a non uniform charge which is given by ρ= Ar²,
with A a constant and r<R measured from the centre of the sphere
(a) Show that the electric field outside the sphere is equal to E = (AR5)/(5ε0r²)
(b) Show that the electric field inside the sphere is equal to E = (AR3)/5ε0)
No attempt, I am completely clueless about what to do here.
Pardon my english, not a native speaker.
Hello Dg, :welcome:
Your english is just fine and certainly good enough to read the guidelines . There you will find that we can't help unless you make an effort.
As a welcoming gesture: did you notice the charge density is spherically symmetrical :rolleyes: ? And does that remind you of a useful theorem named after a long-dead german genius :wink: ?
BvU said:
Hello Dg, :welcome:
Yes i know it's somthing to do with Gausses law, Φ = ∫ EdA which i can then change into Q = ρ EDV
I can fill in ρ as the Q/ Volume of sphere and dV for a surface area. But than i am stuck with an integral i do not know how to solve.
Write down the complete expression for that integral (counts as attempt at solution !)
Well the full expression then would be Q = ∫r0 (q/πr4)r(4πr²dr)
My apologies, i do not know how to put a combination of sub and super script on an integral, the 0 is supposed to be at the bottom.
yeah, the ordinary fonts aren't very good at that. To do it right you need ##LaTeX##
I interpret your formula as $$ Q = \int_0^R {q\over 4\pi r} r \; 4\pi r^2 \,dr $$ correct me if I am wrong (i.e. for example: upper limit R not r)
Can you explain what your Q stands for and how you set it up to look like this ? What is lower case q ?
And we are talking about part (a) with ##r > R##, right ?
With Gauss' law in this spherically symmetric case, you can write ## E = \displaystyle {Q\over 4\pi\varepsilon_0 \; r^2}\ ## with ##Q## the total charge; agree ?Also: re exercise shrewdness :wink: : if you see a 5th power of R divided by 5 in the answer desired, doesn't that ring a bell about a possible integrand ?
##\mathstrut##
Yes about part (a).
the lower case q should be uppercase, my mistake. The Q stands for the charge of the whole sphere.
And yes i agree with that part, But i don't think i can fill in Q by what i have managed to get to find E or can i?
Also, i suppose it doesn't ring a bell for me as i have no idea how that could lead me to a possible integrand.
Oh and btw, thank you very much for helping me!
You are welcome.
If your q is actually Q then you have a circular reference in excel language :biggrin: : the variable is both on the left and on the right side of the equation
The expression to get Q when given ## \ \rho = Ar^2\ ## is what we are still struggling with, right ?
If, in a small volume ##dV\, ## the charge density is ##\rho, \ ## then the charge in that small volume is ##\rho dV##.
For a larger volume ##V## with a charge density ##\rho(\vec r)## (depending on position), the total charge is then ##Q=\int_V \rho(\vec r) \, dV##.
Can you now write the correct version of your integral in #5 ? You have all the ingredients!
