Electric Field's Force on a Suspended Plastic Ball
8 replies · 2K views · last reply
EsinDerin
A small, 4.0-g plastic ball with charge Q=8uC,is suspended by a
cm-long string in a uniform electric field ⃗ E=9.8x10^2 in figure. If the ball is in equilibrium, Find
a) the tension force in the string
b) the angle between vertical axis and string.
E=k*q/r^2
k=1/4Eopi
Hi,I couldn't do this problem.I hope someone could help meths is my first time in this forum
You need to show us how much you can do. You must have some idea how to solve this?
Welcome to the PF. :smile:
EsinDerin said:
Homework Statement:: A small, 4.0-g plastic ball with charge Q=8uC,is suspended by a
Relevant Equations:: E=k*q/r^2
k=1/4Eopi
In addition to showing your work, please try again to attach the diagram of the problem. How many cm long is the string?
This is the question
  • Physics diagram of a small charged ball hanging from a string at angle theta from vertical, with length l and mass m, in a uniform field of arrows pointing right, plus a text problem asking for tension and angle.
Ah, that helps. Okay, please show us your free body diagram (FBD) for the plastic ball, and write the equation for the force of the electric field on a charged body (it is similar to the equation you wrote for the electric field from a charged particle above). Please show us your work. Thanks.
Handwritten physics solution on lined paper: a coordinate sketch with x and y axes, a free-body diagram showing tension T, Tx, Ty, electric force Fe, weight mg and angle θ, followed by force-balance equations and the solution T = mg/cos63° = 2x10^-2 N.
I'm not sure about the solution.If there is any mistake,please show it.Thanks :)
It all looked good until you came to the calculation. Why didn't you do:
$$\tan \theta = \frac{qE}{mg}$$
You made a mistake writing down the charge, which is ##0.8 \mu C##.
One minor point is that you shouldn't mix vectors like ##\vec{F_e}## and scalars like ##T_x## in the same equation.
Ok,are the answers are correct,I would be happy if you answer
It's wrong because you used the wrong charge.
