Electric Potential (Charged Plane)
1 reply · 4K views
GDGirl
Teacher explained the solution- thanks!
Hi GDGirl,
GDGirl said:
The electric potential of a very large flat metal plate is Vo = 69 V. It carries a uniform distribution of charge of surface density σ = 0.29 μC/m2. Determine the electric potential V at a distance x = 3.3 cm from the plate. Consider the point at x to be far from the edges, and assume that x is much smaller than the plate dimensions.
V=V0+Ex
I don't believe this is quite right. Remember that when you move away from positive charges the potential decreases. Do you see what it needs to be?
E=σ/ϵ0
This could be true, but not the way I read the problem. The formula you have here would be true if they meant that the plate was thick and that each side had σ = 0.29 μC/m2. However, if they meant that the plate was thin, then you would have for the magnitude of the electric field:
[tex] |E| = \frac{\sigma}{2\epsilon_0}[/tex]
so that might be another problem.
