Electric potential energy and electric potential.
Electric potential, or voltage, refers to the potential at a specific location in space, while electric potential energy pertains to the energy associated with a charge placed in that location. A position can have a high electric potential even if the potential energy is low, which occurs when a small charge is placed in a region with a strong electric field, such as near a large point charge. The relationship between electric potential and potential energy is defined by the equation V = E/q, where V is voltage, E is potential energy, and q is the charge. Thus, a high electric potential can exist without high potential energy if the charge is small. Understanding these distinctions is crucial for grasping concepts in electrostatics.
cerberus9
I've just come across a lot of concept questions about electric potential energy and electric potential, and I can't differentiate between the two really. I know electric potential is also called voltage.
Here's one question for example:
How can electric potential be high when electric potential energy is relatively low?
Electric potential only involves one charge, and electric potential energy involves two charges, right? That's all I've got. >.<
Potential is a quantity (or quality) of a position in space.
Potential energy is a quantity of an object in that position of space.
That is, a position will have a certain potential, say 15 V. That means any charge placed there will have 15 joules of potential energy for each coulomb of net charge for the object. A volt is equivalent to a "joule per coulomb." Notice how that basically is the same as the formula V=E/q , which is what defines the potential of any location.
An object of greater net charge will have more electric potential energy when placed in that same position.
So in what manner can you have a position at great potential, but an object with low potential energy?
So if you had a relatively small charge in a very powerful space, then the electric potential would be high and the electric potential energy would be low?
Essentially, yes. But don't call it "powerful," because power is a different thing. A high potential can be caused by being NEAR a large point charge. The potential of the space surrounding a point charge,Q, is (V=kQ/d). So when you put a second charge,q, in the vicinity of the first charge, the second charge will have potential energy of E=qV = kQq/d .
Notice that ultimately it doesn't matter which of the two charges you consider "first" or "second."
and sorry about the "powerful" thing, I just wasn't sure about what word to use.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
