Electric potential vector or scalar sum?
The discussion clarifies that electrical potential is a scalar quantity, specifically emphasizing that it is calculated as a scalar sum of individual potentials from point charges. The negative potential indicates attraction for positive charges and repulsion for negative charges, without implying direction. The net potential energy for a proton positioned between two charges (+6e and -10e) is calculated as -4eV, demonstrating the relationship between potential energy and kinetic energy. Understanding this concept requires a shift from force-based thinking to energy-based reasoning.
  • Understanding of electrical potential and potential energy
  • Familiarity with point charges and their interactions
  • Knowledge of scalar versus vector quantities in physics
  • Basic grasp of energy conservation principles
  • Study the relationship between electric potential and electric field strength
  • Learn about potential wells and barriers in electrostatics
  • Explore the concept of electric potential energy in multi-charge systems
  • Investigate the mathematical formulation of electric potential using Coulomb's law
Students of physics, electrical engineers, and anyone interested in understanding the principles of electrostatics and energy interactions in electric fields.
rickywaldron
I'm having trouble fully understanding what electrical potential means. If there are two point charges of opposite signs and a point charge somewhere around them, we simply add the two voltages separately? Not as a vector sum?
Also the concept of negative potential, does this mean that the force is directed towards the charge as opposed to away?
It's the amount of work needed to get a unit positive charge to that spot.
It is a scalar sum because work is not a vector quantity.
However, scalars are allowed to be negative.
The minus sign on the potential does not indicate direction.
A negative potential is attractive to a positive charge and repulsive to a negative charge.
I think you need to review the relationship between potential, potential energy, and work.
Ok, so if I move a proton to the mid point between 2 point charges -10 and +6 it will gain energy from the force it had to use to move against the positive charge, but it will lose even more evergy than this from the negative charge attracting it? Hence the electric potential energy and voltage is negative?
That's pretty much it. Your example, you didn't specify the units for charges. If the proton (charge +e) were (distance x) mid-way between a charge of +6e and -10e then the net potential is given by:
V=\frac{6ke}{x}-\frac{10ke}{x} = -\frac{4ke}{x}
You should be moving away from a force approach to motion and more towards using energy instead. There will be a transition where you will find forces easier to visualize.
The proton is acted on by a net force, the total work is associated with this net force via W=F.d (note that force and displacement are vectors?)
You can expand the F term into each individual force, and each force into components along and perpendicular to the displacement, getting a big sum ... each term of the sum will, itself, be work (energy) and you'll see how some of the terms will be positive and some negative. Thinking in terms of energy becomes very convenient later.
If you imagine a system of two charges, and you move a proton to a position where one charge contributes +6V and the other contributes -10V then the proton, by virtue of being in that position, has -4eV potential energy[1].
If you then move it into a position where is has -7eV potential energy then it has gained 3eV kinetic energy. If you wanted to return it to where it has 0eV potential energy, you'd have to give the proton 7eV of kinetic energy (somehow) to get it there.
You can imagine the same thing with gravity ... gravitational potential energy [close to the Earth is approximated by] mgh, where h is measured upwards from the ground ... this can be a negative number, for instance, if your mass is down a hole.
For this reason, regions of negative potential or often called "potential wells". (Regions of positive potential are called "barriers".)
[1] spot the units ... eV = electron-volt: convenient for protons which have the charge of a single electron only positive. I could have expressed potential as J/e instead of Volts which is J/C and then expressed energies as Joules.
  • · Replies 22 ·
  • · Replies 23 ·
