[Electrical force] 2 balls hanging from ceiling
  • Thread starter Thread starter sea333
    Balls Force
The discussion centers on calculating the forces acting on two hanging balls, each with a mass of 144g and the same electric charge, suspended in a daisy-chain arrangement. Participants clarify that the gravitational and electrostatic forces act on the balls, not on the threads themselves. The net force on the threads is zero if the system is in equilibrium, as the forces from the ceiling and the balls balance out. The conversation highlights the importance of precise language in physics problems, particularly regarding the distinction between tension and net force.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of gravitational and electrostatic forces
  • Familiarity with concepts of equilibrium in physics
  • Ability to interpret and analyze physics problem statements
  • Study the principles of electrostatics, focusing on Coulomb's Law
  • Learn about tension in strings and how it relates to forces in equilibrium
  • Explore examples of systems in equilibrium involving multiple forces
  • Review problem-solving techniques for physics problems involving multiple bodies
Students of physics, educators teaching mechanics, and anyone interested in understanding forces in equilibrium systems.
sea333
A ball with mass 144g hangs from a celling on a thread. Second ball is attached to the first ball with 20 cm thread. They both are charged with the same electric charge. How big is a force that is functioning on a thread?
F=ma
You have to tell us some additional things like:
If the balls have both the same mass and charge
If the system is in equilibrium
Which thread tension you wish to found.
They are both charged with the same charge as I already specified.
No information about if they are the same weight. Assume they are both the same weight.
The combine force in the thread.
sea333 said:
Homework Statement:: A ball with mass 144g hangs from a celling on a thread. Second ball is attached to the first ball with 20 cm thread. They both are charged with the same electric charge. How big is a force that is functioning on a thread?
Relevant Equations:: F=ma
I suspect that either the problem statement is incomplete or that the suggested "correct" answer is not correct.
We are told the mass of the two balls. We are told that they are hanging from the ceiling in a daisy-chain arrangement with threads. We are given some information about a repulsive electrostatic force between the two balls. But we are not given enough information to determine the magnitude of this electrostatic force.
We are asked for the magnitude of a force acting on a thread. Not a specific thread. Just a thread. Not a specific force. Just a force.
If we take the question literally, we might consider the electrostatic force acting on the top thread. Zero.
Or we could consider the contact force of the top ball on the top thread as you have done. Up to a possible sign error (you were asked for magnitude, not direction) your result is correct. The electrostatic force is an internal force and cannot change the net weight of a closed system. The weight of the system is the sum of the weights of the two balls, i.e. ##F_\text{g1}+F_\text{g2}##, just as you say.
You have clarified somewhat that you want to know:
The combined force on which thread? Oh, I get it. Either one.
What is the net force on the thread connecting the two balls? That is, what is the sum of the force of the top ball on that thread and the force of the bottom ball on that same thread.
You can determine that result quite simply.
I mean all the forces working on the thread combined. A sum of all the forces working on that thread.
Which are only force of gravity and electrical force. And the sum of all those forces working on a thread should be 0.
I have provided all the information from the book. I have translated the exercises from the book and it is in my native language.
And the correct result should be 0.
Good. Now show us a calculation of that sum.
Alternately, consider what Newton's second law says that sum must be.
Something like that?
Fthread = Fg1 + Fg2 + Fe1 + Fe2
Your work in the picture is towards finding the tension of the thread that is hanging from the ceiling. However here you tell us that you wish to find the combined forced on the thread which is a different thing. Which forces are acting on the thread and from which bodies?
As I understand the exercise there are 2 forces acting on these thread, gravitational and electrical. And the sum of both is suppose to be 0.
Something like that, yes. But pay attention to signs. That formula is littered with sign errors. Please show your work.
Also, please give Newton's second law some thought.
I think that this is correct?
Fthread = -Fg1 - Fg2 - Fe1 + Fe2
Fthread = Fg1 + Fg2 - Fe1 + Fe2
Nope. You're just guessing now.
What is the force of the bottom ball on the thread?
What is the force of the top ball on the thread
Show your work.
No, the threads are not charged, so no electrical force, and if they are taken to be massless then no gravitational force.
What two forces do act on each thread?
As far as I can understand, if the thread is massless or the system is in equilibrium, the sum of forces on the thread is zero, simple as that.
I would say this is correct:
so 2 gravitational forces point down and 1 electrical force is pointing up
gravitational and electrical force
Nope that's wrong, on the thread that is hanging from the ceiling acts a contact force from the ceiling and a contact force from the body of mass m1=144. IF the system is in equilibrium (and hence the thread is in equilibrium) what is the sum of these two forces?
The gravitational and electrical forces act on the two bodies, not on the two threads.
Did you not read the rest of post #13? gravitational and electrical force act on the balls.
As you said there are 2 threads :
Fthread1 = Fg - Fe //upper thread
Fthread2 = - Fg - Fe
Yes there are two threads, but I am afraid you do not understand what the question is asking that's why you giving wrong answers.
what is it asking ?
yes but we need to know the sum of all forces on all threads
sea333 said:
what is it asking ?
Take the thread as a separate body, name it body A. What forces are acting on this body A?
2 Electrical forces and 2 gravitational forces
The electrical and gravitational forces act on the two bodies of mass m1 (and charge q) and mass m2 (and charge q), not on the threads.
aha I understand that, but what is then acting on the threads?
read again post #17 please.
You mean like that?
Fthread = Fceiling + Fbody = 0
sea333 said:
You mean like that?
Yes! simple as that since the thread is not moving the sum of forces on it is zero.
but where is the electrical force and what about all the rest of information (mass, charge, distance)
  • · Replies 21 ·
