Electrically attaching to Aluminium
  • Thread starter Thread starter Curious P
    Aluminium
The discussion revolves around methods for electrically connecting to a thin aluminum layer, particularly in the context of overcoming challenges posed by the aluminum oxide layer. Participants explore various techniques, including soldering, mechanical contacts, and plating methods, while considering the implications of the aluminum's thickness and support structure.
  • One participant notes that soldering is ineffective due to the aluminum oxide layer, and while ultrasonic soldering has had limited success, the yield is poor.
  • Another participant suggests welding or mechanical contact as alternatives, questioning whether the aluminum layer is thick enough for welding and emphasizing the need for high-pressure mechanical contacts to prevent oxide formation.
  • A different participant mentions that electrolytic capacitors likely use pressure or temperature spot welding for connections to aluminum foil, implying that this could be a relevant technique.
  • One participant proposes a process called 'zincating' to coat aluminum with zinc before applying electroless coatings, detailing the steps involved in the process.
  • Another participant discusses the possibility of using photolithography to pattern gold pads on the aluminum layer, suggesting that this could lower contact resistance and improve connectivity.
  • There is mention of using a deposition system with in-situ ion beam milling to remove the oxide layer before depositing gold, as well as the potential for mechanical methods if clean room access is limited.
Participants express a range of ideas and techniques without reaching a consensus on the best approach. Multiple competing views remain regarding the most effective method for achieving electrical connections to the aluminum layer.
Participants highlight limitations such as the thinness of the aluminum layer (approximately 2 microns) and the challenges associated with melting the material. There are also unresolved questions about the effectiveness and feasibility of the proposed methods.
Curious P
Hi guys,
Not sure whether this belongs in elec or mats/chem so I thought I'd put it here.
Basically I am trying to extract current from a thin aluminium layer.
Due to the Al-Oxide layer, simply soldering an external lead isn't working.
I'm able to etch away (some?) of the oxide layer but even then, soldering is still very dificult/impossible. Ultrasonic soldering has had some (limited) success but the yield has been very poor (1 in 10-15 attempts actually gets a decent bond)
The solder's I've tried are the lead free variety (99.5% Sn, rest Cu) and regular 60/40.
I've read of some special Al-solders but they seem to be 60%+ Pb? (trying to stay away from it)
Another approach I've looked into is electrolysis or electroless plating. However a few of the companies and businesses I've contacted have told me they don't do it and it's very difficult.
In saying that I haven't actually tried it myself (most promosing might be electroless nickel plating?)
Any ideas out there / Any approaches I'm missing?
Thanks for reading
The two possibilities that come to mind are welding and mechanical contact. You can weld aluminum with some special welders (TIG maybe, I'm no expert on welding by any means):
http://www.lincolnelectric.com/knowledge/articles/content/alum.asp
Is your Al layer thick enough to weld to, or is it too thin for that?
The other possibility is mechanical contact, like with spring fingers or a screw-type clamp. The contact needs to be high pressure enough to be gas tight (so Al oxide cannot form), and it is a good idea for the mechanical contact to be at multiple high-pressure points, rather than spread across an area. That's why a star washer is a better choice for an electrical contact at a bolt hole, rather than a flat washer.
Would either of those work? I may move this thread to more of a chemistry-oriented forum for better views at some point.
The people who make electrolytic capacitors must have this one licked...
The leadout wires are presumably pressure/temperature ?spot? welded to the aluminium foil inside the capacitor.
How much further that gets you I don't know.
I do remember brazing two bits of aluminium together, and they stayed together for 10 years before the flux ate into the joint & it fell apart.
Appreciate the responses guys.
The layer is about 2microns thick, supported by glass.
I don't think anything that melts the material would be suitable
Mechanically compressing sounds interesting. I will look into that, but another problem is that the Al is about 1mm wide (by an arbitrary length)
If you think it belongs in a Chemistry based forum that's fine, thanks.
Thanks for the info on the Al electrolytic caps (at least someone has a use for that oxide layer!), I'll check out how they are connected there aswell.
Any more practice or suggestions are much appreciated
I'm moving this thread from General Engineering to Materials & ChemE to see if there are other ideas for Curious P.
I believe you would need to galvanically coat the aluminum with zinc first, a process known as 'zincating'. The procedure would be something like 1) wash with mild alkaline cleaner (sodium bicarb with a little sodium carbonate added) 2) dip rinse quickly in water 3) followed by an acid wash (3 sec, dilute nitric) and finally 4) immersion into a stirred zinc oxide solution (30 sec to 1.5 minutes). This will leave you with a very thin zinc coating on the aluminum which can be electroless coated with gold or nickel. Zincating solutions and procedures should be commercially available in kits such as that by http://www.caswellplating.com/kits/zincate.htm"
Sounds like your samples are very similar to the ones I am using (although my samples are of course patterned). Anyway, the best way to do this is to use photolithography to patterns some gold pads on your samples, this is the standard method of doing it and had the advantage that the contace resistance is pretty low.
How are your films deposited? Would it be possible to deposit e.g. 100-200 nm of gold on top of the Al in-situ? Maybe with a thin sticking layer of e.g. Ti. You can then etch away Au from parts of the sample and define the pads that way. Alternatively, if you have access to a deposition system with in-situ ion beam milling (to remove the oxide) you might be able to deposit some gold on existing sample. This would be the simples way of doing it and you might even be able to use a mechanical mask (i.e. no need to spin resist etc)
If you don't have access to a clean room I would also suggest some mechanical method, if you are only interested in room temperature measurments even a simple probe station with sharp probes might work.
9K
  • · Replies 0 ·
18K
  • · Replies 22 ·
  • · Replies 19 ·
10K
  • · Replies 96 ·
14K
