Electricity and magnetism ( word problems )
The discussion centers on solving physics word problems related to electricity and magnetism. Key topics include calculating voltage change when work is done on a charge, understanding the safety of staying inside a car during a lightning storm, and combining resistors to achieve a desired resistance. The correct approach to these problems involves applying fundamental physics concepts such as electric potential energy, the properties of a Faraday cage, and the behavior of currents in conductive materials.
  • Understanding of electric potential energy and voltage calculations
  • Knowledge of the principles of a Faraday cage
  • Familiarity with resistor combinations in parallel and series
  • Basic concepts of magnetic fields and their effects on metallic objects
  • Research "Electric potential energy and voltage calculations" for deeper understanding
  • Study the "Faraday cage effect" and its applications in electrical safety
  • Learn about "Resistor combinations in parallel" to solve circuit problems
  • Explore "Magnetic fields and their interactions with metals" for MRI safety protocols
Students studying physics, educators teaching electricity and magnetism, and professionals involved in electrical safety and engineering.
chipM
please cheack my answears and see if they are right, please help me solve the wrong ones
thankyou !
(1)if you were to expend 10 J of work to push a 1 C charge against an electric field , what would be its change of Voltage ?
voltage = electric potential energy / charge
10/6.25x10^18
=1.6x10^-18 V
(2)(why is it safe to remain inside a car during a lightning storms?)
since like charges repel the electrons on the metal surface repel electrons of the lightining bolt hence its safe .
(3)your elcetronics friend needs a 20 ohm resistor and only has 40 ohm resistors , how can he combine them to produce a 20 ohm resistor ?
by putting them in parallel
(4)when preparing to undergo an MRI scan, why are patients advised to remove eyeglass watches jewlarry and other metal objects ?
(seriosuly i got no clue for this , maybe a hint? or two ? )
On #2 -- Your answer is not correct. Think about it some more and try again? You can probably even use Google to help you figure it out.
on #4 -- How do MRI scans work? They don't use X-rays; what do they use instead?
cool i am on it
is 1 and 3 correct though ?
for 1 is it
If the vehicle is struck the charge would be distributed across the conductive surface so contact should not be made with the inside of the vehicle until it has been discharged?
for 4)
they are told to remove their jewlarry because of the magnetic field which can attract metals and as a result can pose risk to the patient or anyone in the room as the object is forced to move to the centre of the Mr system ?
chipM said:
for 1 is it
Not quite. There are two issues at work helping to protect the occupants. Read about Faraday Cage at wikipedia to see if it helps with one issue. The other has to do with how currents flow. What path does current seek out?
chipM said:
for 4)
Sounds reasonable.
chipM said:
cool i am on it
#1 looks right, but I didn't check the math. on #3, I'd be explicit on how many resistors he should put in parallel. The wording of the problem makes it sound like he could have more than 2 resistors...
Regarding 2)
is it because the car spreads out the charge around the cars exterior , which cancels out the charge in the cars exterior ?
chipM said:
Regarding 2)
Nope. Think more in terms of currents, rather than charges...
chipM said:
cool i am on it
For 1 a volt is a Joule/Coulomb. The units you are giving the potential in are Joule/e where e is the charge of a single electron. Not volts.
is it because of the change in magnetic field causes in induced voltage, this voltage opposes the supply voltage to slow the build of current. when current become constant here is no voltage . is this it ?
Nope. Let's say you are driving your car, and a power pole falls over next to you and the energized power wires lay across your car. Should you get out of your car and run away?
no because there is current outside .
