Understanding Equilibrium in Electrochemical Reactions
  • Thread starter Thread starter Eureka99
    Electrochemistry
This discussion centers on the interpretation of the Pourbaix diagram for chlorine and its disproportionation reactions. Participants clarify that equilibrium in electrochemical reactions, particularly half-reactions like Cl2/HClO, cannot be understood in isolation; a complete cell with two half-reactions is necessary. The equation E = 1.6 - 0.06 pH illustrates how pH influences the equilibrium potential, indicating that while concentrations of species can vary, the Pourbaix diagram predicts the dominant species in the solution based on their concentrations.
  • Understanding of Pourbaix diagrams and their applications in electrochemistry
  • Knowledge of half-reactions in electrochemical cells
  • Familiarity with the Nernst equation and its derivations
  • Basic concepts of pH and its effect on chemical equilibria
  • Study the Nernst equation and its application in calculating equilibrium potentials
  • Explore the concept of electrochemical cells and their components
  • Research the implications of pH changes on electrochemical equilibria
  • Examine case studies involving Pourbaix diagrams for various chemical species
Chemistry students, electrochemists, and researchers interested in the dynamics of electrochemical reactions and their equilibria.
Eureka99
Hi everybody!
While I was studying the Pourbaix diagram of chlorine ( and its disproportionation), I got stuck in a conceptual problem about the potential E. The diagram, as I understood, it's supposed to represent the equilibrium between the various species, but knowing that at equilibrium the ΔG of the reaction is zero, E have to be zero as well. But I kinda feel that this concept isn't applicable to half-reactions (like this case, in which the equilibrium is between Cl- / Cl2 , Cl2/HClO and so on). If it's not applicable, then why is it so? And then, what does the equilibrium mean in this case?
Thanks in advance
Chemistry news on Phys.org
Hard to speak about an equilibrium of a half reaction - for an equilibrium you need a whole cell (two half reactions).
I thought about that too, but I still don't understand a couple things about the Pourbaix diagram. Like, I don't know how to visualize the equilibrium in the solution, for example, on my book it is said that on the line that represents the coexistence of Cl2 and HClO the following expression is valid:
E= 1.6 - 0.06 pH that is derived by E= 1.6 + 0.03 log ( [HClO]^2 * [H+]^2 / [Cl2] )
So from this expression is it implicated that I can change the concentration of the species as I want and the equilibrium will exist with those concentrations, or will the concentrations of HClO and Cl2 be fixed?
Pourbaix diagram tells you which species are dominating the solution. It is not like others are not present.
If you add anything to the solution that has somehow (it doesn't matter how for this discussion, let's say "by external means") forced its pH and E, this added species will react (with whatever the "external force" needs to supply) till the solution is dominated by what the diagram predicts. In normal situation adding something can easily change the pH and E, moving the system into another area on the diagram.
Ok, now I think I understand, I didn't see that way. Thank you for your help!
