How Do You Calculate the Potential of an Electric Dipole at a Distance?
  • Thread starter Thread starter asdf1
    Electrodynamic
To calculate the potential of an electric dipole at a distance, one must consider two equal and opposite charges separated by distance d. The potential at a point far from the dipole can be approximated by calculating the contributions from each charge and using Taylor expansions to simplify the equation. When the distance r is much greater than d, the potential can be expressed as V = kqd/(r^2 - 0.25d^2), where terms involving d can be neglected if they are significantly smaller than r. It is important to remember that while the potential approaches zero as r increases, it is not exactly zero, and the potential due to a dipole decreases more rapidly than that of a point charge. Understanding these approximations is crucial for solving dipole potential problems effectively.
asdf1
Can someone explain how to solve the following problem?
A physical electric dipole consists of two equal and opposite charges (+/-)q
separated by a distance d. Find the approximate potential at points far
from the dipole.
What have you done up till now ?
Besides, you should have posted this in the HOMEWORK section.
This site gives the formula's you need, which you should also find in your textbook:
Dipole
regards
marlon
yeah, these problems were a bit of a pain, i thought.
find the potential at a far away point from the first charge. then find the potential at the same point for the second charge. add'em.
then you use a ton of approximations to get a neat solution. iirc correctly, be prepared to use taylor expansions... and then you can throw away all but a few terms.
If the point is far from the dipole and not on the axis of the dipole then you can resolve the dipole along the line joining the mid-point of the dipole to the point and at rightangle
to it. potential due to perpendicular component is zero and the point is on the axis of the other component. You can use the formula for axil position.
opps~
new user...
thank you!
but I'm not too clear on how to make the approximations?
-q...M...q.......P
*...d...* .
...< ---------------r-------------->
If the point is at distance r from mid point of the dipole along the axis of the depole then the potential is
V = kq/(r - 0.5d) - kq/(r + 0.5d) = kqd/(r^2 - 0.25d^2)
then what if r >> d
i see~
that clears a lot of things up!
thank you~
so if r>>d, then it V would be approximately 0?
here if r>>0.25d but r is not very large we can neglect only 0.25d^2 as compared to r^2
say r =0.20 m and d= 0.001 m then r^2 = 0.04 m^2 and 0.25d^2 = 0.00000025 m^2, so as compared to r^2 we can neglect0.25 d^2, but can't say that the potential at 0.20 m is zeroo. Right?
I think the confusion might be if you assume
r-0.5d\approx r and r+0.5d\approx r
Then, it seems that the equation becomes
V= \frac{kq}{r-0.5d}-\frac{kq}{r+0.5d}\approx \frac{kq}{r}-\frac{kq}{r}=0
If we are approximating, V is nearly equal to zero not exactly zero and we know that the potential, due to a point charge, is inversly proportional to squre of the distance, will be small enough and due to a dipole will be still smaller.
This is a little video explaining the approximation techniques that you could use here. Taylor series and binomial expansion.
http://physicsstream.ucsd.edu/review/taylor.html
