Electromagnetic Repulsion research
The discussion revolves around the construction and functionality of an electromagnet made from a 1 ft. iron nail, insulated copper wiring, and a 1.5 D cell battery. The original poster is attempting to use this electromagnet to repel a small, circular permanent magnet but is experiencing attraction instead of repulsion.
  • Participants suggest various modifications to the electromagnet, including changing the number of coils and battery strength. Questions arise about the necessity of an iron core versus a non-magnetic core, as well as the relationship between voltage and magnetic strength.
There is an ongoing exploration of potential reasons for the observed attraction rather than repulsion. Some participants have offered suggestions regarding the strength of the electromagnet and the materials used, while others are questioning the assumptions about magnetic interactions and the setup of the experiment.
Participants note the limitations of the D battery and discuss the implications of using a car battery or wall socket for increased voltage, raising safety concerns regarding current and resistance.
willynilly
I have made an electromagnet out of a 1 ft. iron nail, insulated copper wiring and a 1.5 D cell battery.
My task is to use the electromagnet to repel a small, circular permanent magnet (1 in. dia., 1/4 in. thick)
For some reason, I can only get the electromagnet to attract the permanent magnet. All of my research says that magnets, whether electromagnets or permanent, will attract when opposite poles connect and will repel when same poles connect.
I've done everything I can think of to try and connect the same poles. I've tried flipping around the permanent magnet, connecting the permanent magnet to each end of the electromagnet, and switching the end of the wire connected the negative side of the battery to the positive side and vise versa.
What can I do to make my electromagnet repel the permanent magnet?
Thanks
Perhaps your electromagent is too powerful? Try reducing the number of coils. Or too weak even. Have you tested their relative strength qualitively, on a piece of iron say? Beyond that I have no idea, sorry.
Vuldoraq said:
Perhaps your electromagent is too powerful? Try reducing the number of coils. Beyond that I have no idea, sorry.
Hmmm...I don't think it's too powerful, if anything not powerful enough...It can barely pick up a few paperclips.
Thanks for the suggestion though, I appreciate it.
edit: I do have a TON of coils. The entire foot-long nail is covered. I always thought that coils x voltage = strength, so I used as many coils as possible to compensate for the 1.5 D cell battery.
Maybe I'll try using less coils. I'll see what other responses I get here first though.
Thanks
Thanks
Your problem may be that the attractiveness of the iron with the permanent magnet over-matches the strength of the field you are generating with your battery. Maybe try a plastic rod? Or a bigger battery? Or more coils?
That's actually what I thought was the problem at first, but I was told that it wasn't possible because magnets can't be attracting and repelling at the same time. But, maybe the person I asked didn't understand what I was trying to say.
Thanks, I'll see if I can get a hold of a bigger battery.
Also, what would a plastic rod be used for?
To wrap coils without an iron core, which may be the source of your problem.
Or the center of a paper towel roll. Basically anything not magnetic.
Oh...I thought you needed to have some kind of conductive core. I guess I'll give it a try.
Also, is "amperage" simply battery strength? How do I increase amperage, increase battery strength? (I know it's a stupid question, but I'm a totally newb to this kind of stuff)
Thanks
Thanks
Your D battery is pretty limited. 1.5 V in the partial-amp range. A car battery - 12 V and beau coup amps of current might be appropriate, but you need to worry about limiting the current with enough resistance so you don't hurt yourself or your coil doesn't burn if the wire is not thick enough. V = I*R
Also more coils helps to increase the magnetic force you generate.
I think you were right about the permanent magnet's attraction to the the iron nail exceeding the the strength of its magnetic field. I changed from a 1.5 D to 2 AAA's and I noticed that one side of the permanent magnet has a much stronger attraction to the electromagnet than the flip side. I think I just wasn't getting enough voltage through the electromagnet.
Say I did use a car battery, what safety precautions would I have to take? Is there some way I could strip a cord and just plug the electromagnet into a wall socket?
Thanks
Thanks
You of course can do anything, but before you do anything DANGEROUS like wrapping AC cord and slamming a dead short into a wall plug or electrocuting yourself, ask yourself with AC current what kind of magnetic field does it create? Which end will be North? (How often a second?) See a problem with that?
If you use a car battery or more batteries in series, figure what the resistance will be first so you know your current will be relatively safe. (A,B,C,D batteries in series will be safer than a car battery because they have natural limitations on what they can supply. They also discharge faster for a given load you may be sure.
  • · Replies 40 ·
  • · Replies 32 ·
  • · Replies 17 ·
