Electromagnetism - interaction between the electron and the quarks
The discussion centers on the electromagnetic interaction between electrons and quarks within a hydrogen atom, specifically addressing whether Quantum Electrodynamics (QED) or the Standard Model provides the best explanation. Participants agree that QED, as part of the Standard Model, is sufficient for understanding electromagnetic interactions, while the strong force dominates quark interactions. The conversation highlights that the electron does not participate in the strong force and that the gravitational force is negligible in atomic structure. Additionally, it emphasizes the importance of energy scales in observing quarks and the limitations of atomic energy levels in revealing subatomic details.
  • Understanding of Quantum Electrodynamics (QED)
  • Familiarity with the Standard Model of particle physics
  • Knowledge of the Dirac Equation and its implications for atomic energy levels
  • Basic concepts of quantum mechanics and energy scales
  • Study the principles of Quantum Electrodynamics (QED) in detail
  • Explore the Standard Model and its components, focusing on quark interactions
  • Research the Dirac Equation and its applications in quantum mechanics
  • Investigate the role of energy scales in particle physics experiments
Physicists, students of quantum mechanics, and anyone interested in the fundamental interactions within atomic structures will benefit from this discussion.
forcefield
electromagnetism -- interaction between the electron and the quarks
Which theory explains the electromagnetic interaction between the electron and the quarks within a hydrogen atom ? Is it QED or should I look at Standard Model ?
The Standard Model includes QED, so I would say "both."
However, as far as I know the QED part of the Standard Model is sufficient for your question, provided of course that you restrict yourself to the electromagnetic interaction. That is, you're not including the binding of the quarks to each other.
The typical analysis of the H-atom is done outside QFT and consists of the interaction between the proton as a whole and the electron. The interaction with the quarks could be described in QFT as a bound state problem, but this would mean to consider the e-m interaction between the 3 quarks within the proton, which is very small compared to the strong interaction, so that, in the end. you'd still have a bound state problem for the proton as a Dirac particle and the electron as a Dirac particle.
But there is no strong interaction for the electron and it can be very near to the quarks ?
I wonder why there is no answer to my question ? I know that Dirac Equation produces almost correct predictions for the energy levels of the atom and if we take into account also vacuum fluctuations then we get even more correct predictions for the energy levels. But at this point of time instead of the energy levels I'm interested about the electromagnetic interaction between the electron and the quarks. So if we believe that electromagnetic force is behind those energy levels then why do we not need to take into account the different charges of the quarks ? Is there any actual evidence of electromagnetic force inside the atom ? Why can't gravitation be behind what we observe ?
The electron cannot fall into the positively charged nucleus, this is described by QED. The electron does not participate in the strong force. The electromagnetic force does evidence itself within the nucleus. On the other hand, a proton is confined to such a small space that its net charge can be considered as residing at a point for most problems involving electrons.
That you are asking about the gravitational attraction inside the atom indicates you need to spend some more time researching the standard model. The gravitational force is far too weak to make much difference in atomic structure, so much so that it is ignored in treatments.
The answer has to do with energy scales. As you raise the energy, you increase the resolving power and can make out smaller details. Seeing individual quarks requires high energy. But atomic energy levels are quite low, of the order of keV.
As DrChinese points out, the calculation of electronic levels typically assumes a point nucleus. To greater accuracy, one can include a small correction due to the finite nuclear size. But an atomic electron does not have sufficient energy or resolving power to make out the individual protons in the nucleus, let alone individual quarks in the protons.
The gravitational attraction between a proton and an electron is about 10-40 times smaller than their electric attraction.
I was assuming that somehow inside the atom the electromagnetic force might not be there between the electron and the proton as we have no evidence of it.
Sorry, I don't understand this. Which energy are you raising ? What do you mean by "seeing individual quarks" ? Do you mean there is no interaction ?
By the way, welcome to PhysicsForums!
There is evidence for everything in the standard model. Before you make some general statements, you might want to learn more about the subject. There are probably hundreds of thousands of different experiments which have been run over the years. I wouldn't expect you or anyone to know all of these, but it does not make sense to speculate idly in an area in which you can find out more with basic study.
Do you know the charge of the 3 individual quarks in a proton?
Er... where you get this?
Even if you just look at the Schrödinger equation for the hydrogen atom, what do you think is the origin of the potential energy term in that equation? That is the electrostatic potential energy!
Zz.
Sorry, I should have wrote that I didn't know if there is any evidence. After all, this is quantum physics where you can't make experiments without disturbing the system.
In other words: protons are made of 3 quarks. Two have charge of +2/3, and one has charge of -1/3. The sum is +1. An electron has charge of -1. The individual quarks in a proton either attract or repel each other (based on charge), but that attraction or repulsion is overwhelmed by the strong force that keeps all 3 together. But the net +1 effect is discernible outside the proton, and the electron feels its attraction. The electron doesn't really notice that the +1 charge of the proton is split among the 3 separate quarks because they are so close together.
You can make all kinds of experiments that do or do not "disturb" the system. That doesn't really change anything. Evidence is evidence.
This makes no sense, because by implication, you are saying that none of quantum mechanics can be verified by experiment because we are "disturbing the system"!
Zz.
forcefield,
I recommend you read up some more, and then come back with additional questions. This is not stuff you can learn in a few weeks (or even months). There is a lot to learn!
:smile:
Zz.
Sorry, I don't see that implication. Of course it can be verified and has been verified.
So then, why is the issue of "disturbing the system" bothers you?
Zz.
Zz.
After review of the basics of QM it does not bother me any more: according to Dirac in his book The Principles of Quantum Mechanics: "If a system is small, we cannot observe it without producing a serious disturbance." And this is the reason why we need QM.
  • · Replies 21 ·
  • · Replies 65 ·
10K
  • · Replies 17 ·
