Electromagnets and contactor relays
This discussion focuses on constructing an electromagnet for a contactor relay using specific wire gauges. The user determined that to achieve a current of 100mA from a 24V DC source, 500 meters of 31 AWG wire or approximately 670 meters of 33 AWG wire is required. It was clarified that 33 AWG wire is thinner and has higher resistance, necessitating a shorter length. The user successfully completed the electromagnet project and shared images of the final product.
  • Understanding of Ohm's Law
  • Familiarity with wire gauge specifications (AWG)
  • Knowledge of electromagnet construction techniques
  • Experience with basic electrical components and circuits
  • Research the properties of enamel insulated wire (magnet wire)
  • Learn about the design and operation of contactor relays
  • Explore methods for calculating the number of turns for electromagnets
  • Investigate thermal management for electromagnets in prolonged use
Electronics enthusiasts, hobbyists building electromagnets, and engineers designing contactor relays will benefit from this discussion.
raymond621
I am supposed to make an electromagnet for a project.
how will i know what gauge of wire to use and how many turns do i need so that my electromagnet will only get 100mA of current from a 24V dc source?
Thank you!
Hi Raymond
welcome to PF :smile:
do you know Ohms Law ?
if I said Resistance in Ohms = volts / current
can you plug in the values and come up with a value of resistance
then you will need to do some searching on values of resistance per metre (foot) of different gauges of wire
and determine how much wire you need
lets see how you go with the first part for a start :smile:Dave
Thank you sir! Well I have solved it already. I got 2 different gauges of wire to be sure. I need to get less than 100mA of current so,
For the 31 awg wire, I need to have 500 m of wire.
For the 33 awg wire, I need to have 670 m of wire approximately.
My problem is now how many turns or how many times do i need to coil it around my steel core?
Actually I need this electromagnet to make a contactor relay. Is there any more things I need to consider in order to make the relay work for at least 10 minutes?
That sounds the wrong way around
33awg is thinner than 31 awg so it's resistance would be higher and therefore a shorter length needed :smile:
just check your thoughts there
I hope it is enamel insulated wire ? ( sometimes called magnet wire)
you need ALL of it wrapped around the core, except the fly leads off the end to go to the power supply
time isn't an issue with the small current you are drawing from the power supplyDave
Yup, a magnetic wire! Thank you very much for your help Mr. Dave!
you are welcome
post back in the thread at some stage a pic of your electromagnet
and keep us informed on how your experiment is going :smile:
Allright! Thanks again sir!
looking good, have fun with your continued experiments :smile:
