Electroscope Properties (need explaination)
An electroscope with a negatively charged leaf at a 45-degree angle will have the leaf fall when a positively charged metal ball is brought near, as the positive charge attracts the negative charge in the electroscope, causing charge separation. This results in a reduction of negative charge on the leaves, leading to their descent. The confusion arises from the interaction of charges; when a negatively charged rod is brought near, the leaves repel each other due to like charges. The key concept is that the presence of a charged object can induce charge separation in the electroscope, affecting the position of the leaves. Understanding these charge interactions clarifies the behavior of the electroscope in response to external charges.
lnvoker
So I came upon this problem on a quiz (didnt count for marks) about my Static Electricity Unit.
It was like... An electroscope is negatively charged, with the leaf at an angle of about 45 degrees. A metal ball on an insulating handle is slowly brought to (but not touching) the plate of the electroscope and the leaf falls. This suggest that the metal ball is...
  • uncharged or positively charged
  • uncharged or negatively charged
  • positively charged
  • negatively charged
I put #1 as my answer, but got it wrong since my teacher told the class the it would USUALLY be positive charged and not uncharged.
What I'm confused about is how leaf falls when the metal ball is brought upon the electroscope. The only possibility for it to fall would be if the leaves where both neutral or both + or -. (which i have no idea how this would come)
The question before this was similar, but it stated that: A negatively charged rod is slowly brought near the plate of the electroscope (negatively charged), the leaf... (obviously rises since - repels the electrons to the leaves and - and - repel so the leaves repel.
I just don't get the question after. And I'm somewhat confused how the electrons...charges move in the electroscope.
Help would be appreciated.
Thanks :smile:
The positive rod will attract the negative charge on the electroscope, and that negative charge will move from the leaves to the bulb, leaving less excess charge on the leaves.
You should try a + charged rod close to a neutral electroscope. The rod will induce a charge separation on the electroscope - negative on the bulb and positive on the leaves, causing them to repel.
  • · Replies 37 ·
  • · Replies 16 ·
10K
