Eletrons muons tau in string theory
In string theory, electrons, muons, and taus are distinguished by different modes of string oscillations, despite being fundamentally the same entity: strings. The theory posits that these charged leptons acquire their masses through Yukawa couplings, similar to the Standard Model, but the exact vibrational states corresponding to observed particles remain unidentified. The discussion highlights the challenge of reconciling string theory with the Standard Model, particularly regarding the number of generations of particles and the properties of antiparticles like positrons and antimuons.
  • Understanding of string theory fundamentals, including open and closed strings.
  • Familiarity with the Standard Model of particle physics.
  • Knowledge of Yukawa couplings and their role in particle mass acquisition.
  • Concept of topological effects in higher-dimensional manifolds.
  • Research the role of Yukawa couplings in particle mass generation within the Standard Model.
  • Explore the implications of hidden dimensions in string theory and their effects on particle properties.
  • Investigate non-perturbative string theory and its current limitations in phenomenology.
  • Study the relationship between string oscillation modes and particle characteristics in string theory.
The discussion is beneficial for theoretical physicists, researchers in particle physics, and students studying string theory and its implications for the Standard Model.
kodama
in string theory, where strings are posited as fundamental entities, what is the relation between eletrons muons tau
how does string theory explain the increasing masses of leptons
how do these leptons other properties come about in string theory
what about the antiparticles of each? i.e positrons antimuons
in a universe without a higgs field, does string theory distinguish massless eletrons muons tau and if so how?
what prevents strings theory for also having a 4th and 5th and beyond generation charged leptons
similar question for quarks and neutrinos.
Yes. I have wondered whether string theory (with its infinite number of "vibrational states") predict species beyond the (3 leptons for example) species we have observed.
You're basically asking how does string theory reproduce the entirety of the standard model, as well as explaining something that the standard model doesn't explain (the number of generations, the pattern of masses)... which is OK, except that to understand the answer, first you need to understand how all those things work in the standard model, at the level of fields. In the standard model, all those particles are chiral fermions in representations of gauge groups, and (except for the neutrinos) they acquire mass through yukawa terms coupling weak singlets to weak doublets. That's how it works in string theory too, it's just all - done with strings. :-)
thanks for reply, for now I'd like to keep it simple. in string theory where there is only strings as fundamental entities, what is the difference between eletrons muons tau ?
The most common expectation, where flavour is not a gauge group, is that they appear as topological effects in the manifold of hidden dimensions. Think for instance how over a torus you can draw two kinds of circles.
Allow me to put in a vote for "I don't know and neither does anyone else."
The process of trying to build phenomenology out of raw string theory simply isn't there yet.
the mass and properties of these charged leptons never change.
are those topological effects in the manifold of hidden dimensions completely frozen for all eternity?
so the 3 large spatial dimensions can warp and change in the presence of mass-energy
but the hidden 6-7 dimensions are frozen and never changing?
I thought there is only 1 fundamental entity, strings, which can be open or closed, characterized by 1 parameter string tension, and that different open string vibrations correspond to different particles.
Roughly speaking, the difference comes from different modes of string oscillations.
In principle, yes. But nobody yet found the vibrations which correspond exactly to the world we see.
in what specific way does the modes of string oscillations in an electron differ from muon or tau?
what prevents this from happening?
Nobody knows a precise answer.
The current understanding of non-perturbative string theory is actually very poor.
In the stable configurations, the "cycles" in the hidden dimensions (like the paths around @arivero's torus) fill up with a "p-form flux" of virtual strings that create a stiff lowest-energy state of the geometry. The possible higher-energy states above this minimum then involve quantum excitations along the cycles. At very high energies there can be a jump to a different topology.
  • · Replies 47 ·
  • · Replies 30 ·
