How Do You Calculate the Normal Force on a Person in an Accelerating Elevator?
  • Thread starter Thread starter jg727
    Elevator Force
To calculate the normal force on a person in an accelerating elevator, consider the forces acting on the person: the downward gravitational force and the upward normal force from the elevator floor. The normal force can be expressed as the difference between the gravitational force and the net force due to the elevator's acceleration. If the elevator accelerates upward, the normal force increases, while if it accelerates downward, the normal force decreases. The correct expression for the normal force in this scenario is m(g - a), where g is the acceleration due to gravity and a is the elevator's upward acceleration. Understanding these forces is crucial for solving the problem accurately.
jg727
A person of mass m is standing in an elevator of mass M. The elevator is moving downward, but has an upward acceleration of a. To an observer fixed on the Earth, the force exerted on the person by the floor of the elevator is
a. (m+M)g b. m(g+a) c. m(g-a) d. M(a-g) e. M(a+g)
I think I have the Free Body Diagrams correct, but I am confused by finding the normal force on the person by the floor of the elevator.
Any help would be great. Thank you.
There are only 2 forces acting on the person of mass m.
1)The downwards force of gravity (the weight of the person)
2) The upwards force due to the reaction at the floor.
If the person is accelerating upwards there must be a resultant force upwards.
Can you use 1) and 2) to write down an expression for the resultant upwards force.
Then resultant force = m x acceleration
  • · Replies 35 ·
