I Elitzur-Dolev Quantum Liar Paradox
  • I
  • Thread starter Thread starter Quantum of Solace
    Paradox Quantum
Quantum of Solace
I've seen Elitzur's brief presentations on this. Two excited atoms pointed at a detector. The detector goes off, it isn't known which particle fired the photon, so you interrogate one, it gives a definite answer but violates bell's inequality? I'm sorry but I'm lost at such a vague description and this was the best I could find. What is the logic behind this test? I appreciate any references you could offer.
Quantum of Solace said:
I've seen Elitzur's brief presentations on this...
Do you have a reference? Without that, it's going to be hard for anyone to comment sensibly.
Likes bhobba and vanhees71
A quick google search found, well, this very thread. But also these slides:
Screenshot from 2016-07-28 11:53:04.png
Basically it's describing this quantum circuit, where a parity measurement creates entanglement between two qubits that start off separable:
Screenshot from 2016-07-28 11:56:41.png
This is an example of "performing a measurement forces the system into the state indicated by the measurement outcome, even if that state is entangled and you feel like that's weird".
This particular setup works on inputs that are in X-axis states (e.g. On+Off), but not Z-axis states (e.g. just On). Doing an X-axis or Y-axis parity measurement in addition to the Z-axis parity measurement would fix that, but kinda breaks the analogy with the simple physical system. With both parity measurements it's a full fledged Bell basis measurement, which must force the system into one of the Bell basis states (and tell you which one). All of those basis states are fully entangled, so the output is entangled.
It took a while, but I finally found the reference:
http://a-c-elitzur.co.il/uploads/articlesdocs/MultipleIFM.pdf
Section 10, Page 13 "The Quantum Liar Paradox"
Still trying to understand this properly, but it seems to me until the Z measurement (which box?) is performed, each particle Z exists in the blocking(or non blocking) box only as part of a superposed state, and is thus not forced to interact with the photon, leaving it to interfere with itself.
If two entangled particles have a 50% chance of being in the "blocking" box, (mutually exclusive), does that mean one of them MUST interact with a traversing photon? or does quantum mechanics allow a possibility for photons to traverse both boxes? If so, then I'm not sure I get why this is supposed to be a paradox.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
