EM wave power density in lossy dielectric at 2.45 GHz
2 replies · 2K views
derek l
An E field with f = 2.45*10^9 Hz passes through a material with the following properties
e_r = 10
u_r = 1
sigma = 1 (S/m)
The Incident E field has peak magnitude of 300 V/m at the air to surface boundary.
(a) *solved* Find the incident power density at the material surface
p_avg = 1/2*Real[E×H]
because η_o = 120π in free space
p_avg = (0.5)(300)(0.795) ≅ 120 W/m^2 similarly 300^2/2*η_o *correct*(b) Calculate transmitted power into the material at the surface boundary
loss tangent of material = 0.6329 rad^-1 = 18°
η = 106e^(j*18°)
H = 0.795e^(-αz)
E = H*η = 84.25
E = 84.25e^(-αz)
p_avg = 1/2*Real[E×H] = 33.48 *incorrect*
I'm not up on all the relationships between the E and H field amplitudes for the incident, transmitted and reflected waves. But I will point out a couple of things.
derek l said:
η = 106e^(j*18°)
H = 0.795e^(-αz)
You didn't state what ##\eta## represents (maybe impedence?) nor how you arrived at η = 106e^(j*18°). So, it's hard to check your work here.
You are taking H for the transmitted wave at z = 0 to have the same value (0.795 units) as H for the incident wave. But, isn't there also a reflected wave? Shouldn't the amplitude of H for the transmitted wave at the interface be less than the amplitude for H for the incident wave?
Oh yes I'm sorry. η is impedance. I calculated η for the material given the material properties. I agree with your point I will try to find the amplitude for H of the transmitted wave
