EMF and potential in a circuit
Krushnaraj Pandya
Four identical cells each having emf E and internal resistance r are connected in series to form a loop abcd as shown in figure (picture 1). Find potential difference across ab and ac.
2. Homework Equations
V=IR
equations for combination of cells and resistances
this is the circuit diagram-(picture 2. left for across ab and right one for across ac), I can find equivalent resistance easily, what confuses me is the sign of the emf- for ab three cells are sending current in one direction while one is in the opposite direction. So using +E for three and -E for one I get the answer -E/2 across ab but the correct answer is E/2. I think there's a fundamental mistake in my understanding of emf so I'd be grateful if someone can explain it to me in an simple, intuitive way. Thank you.
  • Hand-drawn circuit loop with corners A, B, C, D; each of the four sides has a cell labelled E and a resistor labelled r, connected in series around the square.
  • Two hand-drawn circuit diagrams side by side, labelled A, B and C, each a loop of cells with emf E and resistors R, 3R and 2R.
V=IR
I think the only thing you are missing is the idea that you have to measure the EMF relative to a reference. If you measure the EMF at ##b## relative to ##a## you get one sign. If you measure the EMF at ##a## relative to ##b##, you get the other sign.
Got it after some thinking, thank you :D
