Energy conservation( system of masses)
The discussion focuses on solving a physics problem involving three connected masses (m1 = 800g, m2 = 1100g, m3 = 1200g) using the energy conservation method. The system is affected by friction with a coefficient of μ = 0.345 on m2, which rests on a table. The final velocity of m3 after falling 60.0 cm is calculated to be approximately 0.2806 m/s, taking into account the work done against friction and the potential energy changes in the system.
  • Understanding of energy conservation principles in mechanics
  • Familiarity with work-energy theorem
  • Knowledge of friction and its effects on motion
  • Ability to solve equations involving multiple masses and forces
  • Study the work-energy theorem in detail
  • Learn about the effects of friction on moving systems
  • Explore energy conservation methods in complex systems
  • Practice solving problems involving multiple connected masses
This discussion is beneficial for physics students, educators, and anyone interested in understanding the application of energy conservation in mechanical systems involving multiple masses and friction.
murcy
Problem and Data
three masses conected m1= 800g, m2 =1100g m3=1200g. m2 rest on a table of coefficient μ=0.345. m1 and m3 hang vertically over frictionless/massless pulleys. The system is released from rest. Whats the velocity of m3 after falling 60.0cm
P.S "i know this system can be solve with finding tension and such, but i have to use energy conservation method."
W(work)= ΔK+ΔUg(potential gravitational)+ΔUs(Spring energy)
The velocity for m3 would be the same for all three masses because they are connected by a string. There's no k (initial) and spring energy involved.
This is what i have gotten so far;
I made a system of equations for each body:
Δy i defined as the change of height for potential energy.
m1;
W= (1/2)m1v^2+ m1gΔy
m2;
W= (1/2)m2v^2
m3;
W=(1/2)m3v^2-m3gΔy (the minus from negative displacement in height(Δy))
Im not sure about the following, i think I am missing something;
*I also know that the system is losing energy by the interaction of M2 w/ the surface of the table...friction.
so friction(f)= N(normal)*μ(K).
In other words: f=m2*g*μ
and Work is also =f*r(displacement by the force)* cos (θ)
θ being the angle between the force and the displacement."
I'm just not sure how to related the energy lost W on all three bodies
Thanks for any input or help you guys can provide on my problem.
I think you have 3 masses total, M1, M2, and M3 (you shouldn't change from lower to upper case letters).
Each has the same velocity and each move the same distance.
The equation you have written for Work is for work done by non conservative forces (the work done by friction on M2 in this case). That's the part that goes on the left side of the equation. The change in KE and the change in PE go on the right side, as you have indicated in your relevant equation. Watch signage, and please show your work in arriving at a solution. And welcome to PF!
Hi and thanks :),
sorry about the upper case M.(changed).ok so the work on m2 would be;
w= (1/2)m2v^2
frcosθ= (1/2)m2v^2
N*μ(-1)=(1/2)m2v^2
-mg*μ=(1/2)m2v^2
-(1.1kg)(9.8m/s^2)*(0.345)=(1/2)(1.1kg)v^2
solve for V;
-3.719N=0.55kg v^2
v^2=-3.719N/0.55kg
v^2=-6.762m^2/s^2
v=sqrt(-6.762 m^2/s^2)...i know I am wrong here since ill have a neg inside a sqrt :(, but if somehow the inside is pos ill have v= 2.60m/s...
im sure this is not right :/
I'm sorry but I am still stuck in this problem :/
You can't just isolate one block to determine its speed unless you include the work by the tension forces as well. Instead, look at the entire system of three blocks. Use your original equation, which is
W_{friction} = (KE_{final} - KE _{initial}) + (PE_{final} - PE _{initial}), where the initial and final KE's and PE's of each block must be determined and included in this equation.
Thanks for the reply Jay;
I understand what you mean now, this is what i have so far i hope is right;
Wfriction= (1/2)(m1+m2+m3)v^2+(m1-m3)gΔy
Wfriction=(1/2)(0.8kg+1.1kg+1.2kg)v^2+(0.8kg-1.2kg)(9.8m/s^2)(0.6m)
Wfriction=1.55kg*v^2-2.352joules
earlier i found;
Wfriction=fdcosθ and f=μk*N(m2g)
Wfriction=0.345*1.1kg*9.8m/s^2*0.6m*-1
Wfriction=-2.23 joules
so;
-2.23j=1.55kg*v^2-2.352j
i ended up with v= sqrt(0.07871m^2/s^2)
v=0.2806m/s i wish i could verify this answer but looks reasonable
earlier i found;
so;
yes
Yeah, looks OK!
Thanks a bunch Jay~
10K
