Calculating Energy Dissipation for a Moving Object Using Integral Calculus
  • Thread starter Thread starter Arm
    Energy Force
The discussion focuses on calculating energy dissipation for a moving object using integral calculus, specifically through the equation ##F = -b * v##. Participants explored the transformation of variables from position to time, emphasizing the need to express velocity as a function of time, ##v(t)##, rather than position, ##v(x)##. The final solution derived was ##\frac{-ba^2T^5}{5}##, highlighting the importance of correctly applying integral calculus techniques to solve physics problems involving motion.
  • Integral calculus, specifically integration techniques
  • Understanding of kinematics, particularly velocity and acceleration
  • Familiarity with force equations in physics, such as ##F = -b * v##
  • Ability to manipulate equations and change variables in integrals
  • Study the application of the Fundamental Theorem of Calculus in physics problems
  • Learn about variable substitution techniques in integrals
  • Explore the relationship between velocity, position, and time in kinematics
  • Investigate energy dissipation concepts in mechanics, particularly in relation to damping forces
Students and professionals in physics, engineering, and applied mathematics who are working on problems involving motion and energy dissipation through integral calculus.
Arm
Question
An object moves in one dimension according to the function ##x(t) = \frac{1}{3}at^3 ##, where a is a positive constant with units of ##\frac{m}{s^3}.## During this motion, a force F =−bv is exerted on the object, where v is the object’s velocity and b is a constant with units of ##\frac{kg}{s}. ## Which of the following expressions will yield the amount of energy dissipated by this force during the time interval from t=0 and t=T ?
##ΔE = \int_{x_1}^{x_2} F(x) dx ##
##F = -b*v##
##v(t) = at^2##
Since ##F = -b * v## I said ## F(x) = -b*v(x) ##
Also x(0) = 0 and x(T) = ## \frac{1}{3}aT^3 ##
I made the integral ## ΔE = -b* \int\limits_0^\frac{aT^3}{3} v(x) dx ##
I wanted to replace v(x) with v(t) somehow
I first tried ##v(x) = ax^2## but then realized that was wrong
Then I tried using ## x = v*t ## but couldn't do anything with it
In the integral ##\int v dx##, try switching to a time integration by letting ##dx = \dfrac{dx}{dt}dt##.
That would make it ##\int v(x)*v(t) dt##, I don't know what to do from there. (I've only done a handful of integrals before)
You don't have ##v(x)## in the integrand. You have ##v(t)## by differentiating ##x(t)## w.r.t time ##t##. The Force ##F## is a function of velocity, which is a function of time. That means ##F = f(t)##. While it does vary with position, it does so by varying the function for ##v## in time.
erobz said:
You don't have ##v(x)##. You have ##v(t)## by differentiating ##x(t)## w.r.t time ##t##.
So is ##v(x) = \dfrac{d(x(t))}{dt}##? I'm confused right now about how to represent v(x) as a derivative.
Where are you coming up with ##v(x)##? You don't need it. You have changed the variable of integration from ##x## to ##t##, with the substitution @TSny showed.
##v = v(t) = \frac{d}{dt} \Big( x(t) \Big) ##
If you want to do it the long way solve for ##t(x)##. Then substitute that into ##v(t)##. $$v(x) = v( t(x) )$$ Then, the integral is:
$$ \int F dx = -b \int v( t(x) ) dx = - b \int_{x(0)}^{x(T)} v(x) dx $$
But I think you will find it preferable to transform the integral to the time domain.
$$ \int F dx = \int F(t) dx = -b \int v(t) dx = -b \int v(t) \cdot v(t) dt = -b \int_{0}^{T} {v(t)}^2 dt $$
You should do both so you can play around with these concepts.
To @Arm:
Look,
If ##x = \frac{1}{3}at^3##, it follows that ##v=at^2.##
Following @TSny's suggestion,
##Fdx=F\dfrac{dx}{dt}dt=F(at^2)dt = (-bat^2)(at^2)dt##
Integrate.
kuruman said:
To @Arm:
Look,
Integrate.
My calculus is very bad which is why I don't follow the steps where you change domains, but I ended up solving it by using ##v(x(t))##
Thank you
Thank you
I hope you mean you used ##v(x) = v( t(x) )##, because ##v(x) \neq v( x(t) )##?
Thank you
You are welcome. Since you solved it, will you post the answer that you got?
Yeah that's what I meant, mistyped the reply
## \frac{-ba^2T^5}{5} ##
Arm said:
## \dfrac{-ba^2T^5}{5} ##
You might want to consider whether the result should be positive or negative.
Thank you for posting your solution. Note that if you followed the method in post #8, you could have done it in your head, $$\int_0^T(-bat^2)(at^2)dt=-\frac{1}{5}ba^2T^5.$$It's something worth considering for future reference next time you encounter a problem like this.
  • · Replies 25 ·
  • · Replies 27 ·
