Energy eigenvalues of spin Hamiltonian
The discussion focuses on the Hamiltonian of the positronium atom in the 1S state under a magnetic field along the z-axis, represented as $$H=AS_1\cdot S_2+\frac{eB}{mc}(S_{1z}-S_{2z})$$. Participants suggest using the total angular momentum basis, specifically the states $$|1\,1\rangle, |1\,0\rangle, |1\,-1\rangle, |0\,0\rangle$$, to construct a 4×4 matrix representation of the Hamiltonian. The diagonalization of this matrix will yield the energy eigenvalues and eigenvectors, classified by quantum numbers associated with constants of motion. The computation of the action of the operator $$S_{1z}$$ on the basis states is also discussed, particularly the decomposition of $$|1\,0\rangle$$.
  • Understanding of quantum mechanics, specifically angular momentum and spin states.
  • Familiarity with Hamiltonian mechanics and matrix representations of operators.
  • Knowledge of diagonalization techniques for matrices.
  • Basic concepts of quantum numbers and their significance in quantum systems.
  • Learn how to construct and diagonalize matrices representing quantum mechanical operators.
  • Study the total angular momentum representation in quantum mechanics.
  • Explore the implications of magnetic fields on quantum systems, particularly in the context of the Zeeman effect.
  • Investigate the role of quantum numbers in classifying energy states in multi-particle systems.
Students and researchers in quantum mechanics, particularly those studying atomic systems, spin interactions, and Hamiltonian dynamics.
vbrasic
The Hamiltonian of the positronium atom in the ##1S## state in a magnetic field ##B## along the ##z##-axis is to good approximation, $$H=AS_1\cdot S_2+\frac{eB}{mc}(S_{1z}-S_{2z}).$$ Using the coupled representation in which ##S^2=(S_1+S_2)^2##, and ##S_z=S_{1z}+S_{2z}## are diagonal, obtain the energy eigenvalues and eigenvectors of the Hamiltonian and classify them according to quantum numbers associated with constants of motion.
Not really sure.
The coupled representation as far as I know is just the total angular momentum representation. We have that both the electron and positron are spin half particles, so the total angular momentum basis is, $$|1\,1\rangle;\,|1\,0\rangle;\,|1\,-1\rangle;\,|0\,0\rangle.$$ However, I have no idea where to go from here.
What if you wrote the Hamiltonian as a 4×4 matrix using the basis that you posted and then diagonalized it?
Okay, so to do that I have to see how each operator affects the basis, right? I'm not sure how that would work with ##S_{1z}## for example. That is, how do I compute ##S_{1z}|1\,0\rangle## for example. I suppose one way would be to decompose ##|1\,0\rangle## as $$|1\,0\rangle=\frac{1}{\sqrt{2}}\bigg(|+\,-\rangle+|-\,+\rangle\bigg).$$ Then, we have that $$S_{1z}=|1\,0\rangle=\frac{\hbar}{2}\frac{1}{\sqrt{2}}\bigg(|+\,-\rangle-|-\,+\rangle=\bigg)=\frac{\hbar}{2}|0\,0\rangle.$$ Is that sounding okay?
That sounds fine.
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 21 ·
