Energy Equations: U, K, E for 0-4 cm Compressions
  • Thread starter Thread starter MrGoodyear812
    Energy
The discussion focuses on calculating the spring potential energy (U), kinetic energy (K), and total mechanical energy (E) for a 1.75 kg block sliding on a frictionless surface and compressing a spring with a force constant of 787 N/m. The user is struggling to obtain correct values after initially succeeding with the equations for spring potential energy, kinetic energy, and total energy. They express confusion over why their calculations are now yielding incorrect results despite using the same formulas. Participants suggest starting with Newton's Laws and verifying the equations of motion to ensure accuracy. The thread emphasizes the importance of correctly applying the equations to achieve the right answers.
MrGoodyear812
A 1.75 kg block slides with a speed of 0.880 m/s on a frictionless horizontal surface until it encounters a spring with a force constant of 787 N/m. The block comes to rest after compressing the spring 4.15 cm.
Find the spring potential energy, U, the kinetic energy of the block, K, and the total mechanical energy of the system, E, for compressions of (a.) 0 cm, (b.) 1.00 cm, (c.) 2.00 cm, (d.) 3.00 cm, (e.) 4.00 cm.
HELP!
I've been using the equations:
spring potential = 1/2*force constant*length^2
kinetic = 1/2*m*v^2
total = Spring + kinetic
Start with Newton's Laws, write down the equations of motions and go from there
With the three equations you have, you should get to the right answers. Maybe you want to actually show us what you did, and we will tell you if you did it right.
I've been using those equations and plugged them in (we use an online website) and it was right the first time, and now its not...and logic would state that doing it again would yield correct answers...but I'm not getting them! Why? I haven't a clue.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
