Energy question, involving work, there is a missing variable?
To determine the constant speed of a forklift lifting a 613.0 kg mass with a power output of 950 W, the relationship between power, mass, and gravitational force can be utilized. By rearranging the equation for work (W = mg * d) and dividing by time, the formula simplifies to power (P = mg * v). Substituting the known values of power and mass allows for the calculation of the forklift's velocity. The discussion highlights the importance of understanding how to manipulate equations to find missing variables in physics problems. This approach effectively resolves the issue of not having displacement or time directly provided.
oddcitations
A 613.0 kg mass is placed on a forklift that can generate 950 W of power. What is the constant speed of the forlift while lifting this load?
W = F * change in Displacement ( or (F)(change in displacement)(costheta))
W = mg * Change in displacement
P = W/t
Ekinetic = 1/2mv^2
Work is in joules, power is in Watts.
950 W = W/t (I don't have time or displacement)
W = mg * change in displacement
W = (9.5*613 )* change in displacement(which I do not have)
W = 6007.4 N *change in displacement
change in displacement = vAverage * change in time
change in time = all include velocity, which I am looking for.
Ekinetic = 1/2mv^2
xJ = (613.0kg/2)v^2
xJ = 306.5v^2
I feel like I need displacement or time, but I'm given neither. :\
Good! Now what happens if you take both sides of this equation, and divide them by t?
P = W/t
Ekinetic = 1/2mv^2
Ekinetic = 1/2mv^2
xJ = (613.0kg/2)v^2
xJ = 306.5v^2
take equation w=mg*d
divide both side by t,then u will get p=mg*v
put the values of p,m&g,so find the velocity of forlift...
Ah...
That is so ingenius, I love it! Thank you guys very much! :]
  • · Replies 56 ·
