Calculating Energy Stored and Dissipated in a Capacitor Discharge
  • Thread starter Thread starter NkaujHelp
    Capacitor Energy
The discussion focuses on calculating the energy stored in a capacitor and the energy dissipated by a light bulb during discharge. A capacitor with a capacitance of 1.25 F was charged with a 5 V DC power source and connected to a 20-ohm light bulb. The initial energy stored in the capacitor was calculated to be 15.6 J, while the energy dissipated by the bulb over 25 seconds was calculated as 31.25 J. The discrepancy in energy values raised questions about the assumption of constant power during discharge.
  • Understanding of capacitor discharge in RC circuits
  • Familiarity with Ohm's Law (V=IR)
  • Knowledge of energy equations for capacitors (U=(1/2)CV^2)
  • Ability to calculate power dissipation (P=I^2R)
  • Study the equations governing capacitor discharge in RC circuits
  • Learn about energy conservation in electrical systems
  • Explore the effects of non-ideal components in capacitor circuits
  • Investigate the relationship between current decay and time in capacitor discharges
Students studying electrical engineering, physics enthusiasts, and anyone interested in understanding capacitor behavior in circuits.
NkaujHelp
Prove that the total energy initially stored in the electric field inside the capacitor is equal to the total electrical energy eventually dissipated by the bulb. A 5 V DC power source charged the capacitor. The capacitor was then connected in series with a light bulb with a resistance of 20 ohms and an ideal ammeter. When connected, the ideal ammeter read the current as 20 A. Twenty seconds later, the ammeter read the current as 0.05 A.
The capacitance was calculated to be 1.25 F.
V=IR
C=Q/V
P=IdealtaV = (I^2)(R)
U=(1/2)CV^2
By using U=(1/2)CV^2 and plugging in all the values given above, the total energy initially stored in the electric field inside the capacitor came to be 15.6 J. The power dissipated as heat by the bulb came out to be P=RI^2=(.25A)^2(20 ohms)=1.25 Watts. Converting watts into joules or power into energy, I took 1.25 Watts*25 seconds = 31.25J. I followed and checked the units to be correct and the units came out right. The 25 second is the number when calculated turns out to be the length of time the capacitor completely discharges and the light bulb goes out. So this is only an ideal case. I really don't need any information on non-ideal cases about this. It's just going to confuse me. But I just need help on if my values came out to be right. The energy dissipated as heat by the bulb is way more than the energy provided by the capacitor. I don't see how that is possible.
Is it correct to assume that the power of 1.25 W remains constant during the discharging of the capacitor?
Please show how you calculated 25 s for the discharge time. Have you studied the equations for describing the discharge of a capacitor in an RC circuit?
  • · Replies 16 ·
  • · Replies 16 ·
14K
