Energy to raise temperature of water
The discussion centers on calculating the mass of freshly boiled water needed to raise the temperature of a 0.500 kg pot of water from 40.0 °C to 65.0 °C by adding water at 100 °C. The correct calculation shows that 0.357 kg of water must be added. Participants highlighted the importance of maintaining accurate units throughout the calculations, specifically using c/kg instead of c-kg. Additionally, a participant pointed out that the final mass of water should not exceed the capacity of the original pot, suggesting a need for a larger container.
  • Understanding of heat transfer principles
  • Basic algebra for solving equations
  • Knowledge of specific heat capacity
  • Familiarity with temperature and mass units
  • Study the concept of heat transfer in thermodynamics
  • Learn about specific heat capacity and its applications
  • Practice solving heat transfer problems using algebra
  • Explore the implications of unit consistency in scientific calculations
Students studying thermodynamics, educators teaching heat transfer concepts, and anyone involved in practical applications of thermal energy calculations.
Dazed
Just looking for someone to check my work on this question before I submit it to the teacher. Any help is appreciated. :)
3. A 0.500 kg pot of hot water for tea has cooled to 40.0 OC. How much freshly boiled water must be added (at 100 OC) to raise the temperature of the tea water to a respectable 65.0 OC?
Let n represent the unknown mass of water to be added.
Starting water + Added water = total water
40c x 0.5 kg + 100c x n = 65 (0.5kg + n)
20 kg + 100 n = (32.5kg + 65n)
52.5 kg = 165 n
1 kg = 3.1n
n = 1/3.1
n = 0.32 kg
To raise the temperature of the tea to 65 degrees, 0.32kg of 100c water must be added.
~Dazed
No, you messed up the third step. Subtract 65n from both sides, and 20 kg, to get
35n = 12.5kg
You can finish it from there.
A small additional note: your units aren't complete, when you multiply temperature times mass, the units are c-kg. Won't matter in the end, but keeping accurate track is a good habit.
Thank you for your reply. :)
I think I've correctly fixed this as per your suggestions, I used the units c/kg instead of c-kg, I assumed that was a typo. If c-kg is correct please tell me and I'll change it. Also please tell me if the new answer is correct or of I messed up somewhere again. :)
Starting water + Added water = Total water
(40c x 0.5 kg) + (100c * n) = 65c(0.5kg + n)
20c/kg + 100n = (32.5c/kg + 65n)
20c/kg + (100n - 65n) = 32.5c/kg + (65n – 65n)
20c/kg + 35n = 32.5c/kg
Subtract 20kg from both sides
(20kg – 20kg) + 35n = (32.5kg – 20kg)
35n = 12.5kg
n = 12.5kg / 35
n = 0.357kg
To raise the temperature of the tea to 65 degrees, 0.357kg of 100c water must be added.
Correct answer. You're units are still a little confused. If you multiply 40c x 0.5 kg, you get 20 c kg (whatever that is!). Then when you get down to
35c * n = 12.5 c kg
and solve, you get
n =12.5 c kg / 35 c
and the answer has units of kg as you knew it must.
NO. If you added 0.357kg of water to the pot it would overflow. You would have to add both parts of the water to a 0.900 kg pot and then return 0.500 kg to the original pot.
