Engine Size: 747-400 & Airbus A380 Dimensions
  • Thread starter Thread starter Badass
    Engine
The diameter of the Boeing 747-400 engines, including models from Pratt & Whitney and General Electric, is approximately 2 meters, with specific fan tip diameters such as the PW4000-94 measuring 94 inches (2.39 meters). The Airbus A380 utilizes engines like the GP7000, which has a fan diameter of 116 inches (approximately 2.95 meters). The thrust ratings for these engines vary, with the latest 747-400 models producing 70,000 lbs of thrust per engine, while the GP7000 is rated at 81,500 lbs. General Electric produces the largest engines in this category, with Rolls Royce's Trent engines also being notably large.
  • Understanding of jet engine specifications and measurements
  • Familiarity with aircraft engine manufacturers such as Pratt & Whitney, General Electric, and Rolls Royce
  • Knowledge of thrust ratings and their significance in aviation
  • Basic comprehension of high bypass turbofan engine design
  • Research the specifications of the Pratt & Whitney PW-4000 series engines
  • Explore the General Electric CF6 engine family and its applications
  • Learn about the design and performance of Rolls Royce Trent engines
  • Investigate the differences between high bypass and low bypass turbofan engines
Aerospace engineers, aviation enthusiasts, and professionals in the aircraft manufacturing industry will benefit from this discussion, particularly those interested in jet engine specifications and performance metrics.
Badass
Does anyone know the diameter of the 747-400 engines used please? Obviously there are different manufacturers but I wouldn't have thought that would alter the size. What about the size of the new Airbus A380 engines as well?:confused:
powerplants..
"Four 252.4kN (56,750lb) Pratt & Whitney PW-4056 turbofans or 266.9kN (60,000lb) PW-4060s,
or 275.8kN (62,000lb) PW-4062s, 252.4kN (56,750lb) General Electric CF6-80-C2B1Fs
or 273.6kN (61,500lb) CF6-80-C2B1F1s or -80-C2B7Fs,
or 258.0kN (58,000lb) RollsRoyce RB-211-524G
or -524Hs, or 262.4 to 266.9kN (59 to 60,000lb) RB-211-524G/H-Ts."
(from airliners.net)
The diamemeter are all around 2 meter.
Try this place - http://www.geae.com/ for GE jet engines
http://www.geae.com/engines/commercial/cf6/index.html
and this one for Pratt & Whitney
http://www.pratt-whitney.com/prod_commercial.asp
http://www.pratt-whitney.com/prod_comm_pw4000_94.asp
PW4000-94 Fan tip diameter: 94 in ~ 2.39 m
The fan diameter on the GP7000 is 116 in.
http://www.geae.com/engines/commercial/gp7000/
So it seems that General Electric produce the largest engines ( funny, I thought they were all standard) which makes Rolls Royce engines I don't know how large though. As for the A380 I think they could be 9 ft wide.:smile:
As a note, that is the fan diameter. The actual core diameter will be much less.
Rolls Royce's Trent Engines are similarly large - 116 inch fan (high bypass) for the A380.
http://www.rolls-royce.com/media/product/trent900.jsp
In general, RR products - http://www.rolls-royce.com/media/product/default.jsp
See Trent 800 for 777 engine - http://www.rolls-royce.com/media/product/trent800.jsp
See RB211-524 & -22B for 747 engine - http://www.rolls-royce.com/media/product/rb211524.jsp
The latest 747-400 models have an engine thrust of 70000 lbs. Is this per engine though? If it is I did work it out and know the answer but was wondering if it was per engine. It seems that you certainly wouldn't want to be standing near these engines when on idle.
The 70,000 lbs is per engine! The GP7000 is rated at 81,500 lbs. Jet engines have a clearance area fore and aft. One does not want to get too close to either end. Idle is not too bad, but with thrust the exhaust will 'blow' one away. :biggrin:
http://www.enginealliance.com/images/gpfeat_08.gif
Starting in 1971 with the 40,000 lb. thrust CF6-6 and continuing today with our newest, highest thrust CF6 engine, the 72,000 lb. thrust CF6-80E1, more CF6 engines have been produced and have flown more hours than any other high bypass engine family ever produced.
GE - http://www.geae.com/engines/commercial/cf6/index.html
The Engine Alliance is offering the GP7200 for the Airbus A380 passenger and freighter configurations. The GP7200 will initially certify at 76,500 lb. (340 kN) of thrust and subsequently at 81,500 lb. (363 kN) of thrust. The engine will be offered with two ratings appropriate for the various A380 configurations and take-off weights: GP7270 for the 560 tonne variant, and GP7277 for the 590 tonne A380-800 freighter.
GE - http://www.geae.com/engines/commercial/gp7000/index.html
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 39 ·
  • · Replies 19 ·
