Engine wont start unless I heat up the engine first
  • Thread starter Thread starter Moonbaby39
    Engine Heat
The discussion centers on a 2003 Pontiac Grand Am that requires external heating to start, particularly in cooler weather. Users suggest that the issue may stem from a fuel supply problem, as gasoline takes longer to vaporize in cold temperatures. A potential solution includes using a fuel check valve, which can be a cost-effective fix. Additionally, the discussion highlights the importance of checking the fuel filter and the functionality of the fuel pump, which was replaced three years prior.
  • Understanding of internal combustion engine mechanics
  • Knowledge of fuel vaporization processes
  • Familiarity with automotive electrical systems, particularly electronic ignition
  • Basic troubleshooting skills for automotive fuel systems
  • Research the function and installation of fuel check valves for automotive applications
  • Learn about the effects of temperature on fuel vaporization in gasoline engines
  • Investigate common issues with fuel pumps and filters in older vehicles
  • Explore the benefits and installation of engine block heaters for cold weather starting
Car owners, automotive technicians, and anyone experiencing starting issues in cold weather, particularly with older vehicles like the 2003 Pontiac Grand Am.
Moonbaby39
TL;DR
I'm having a problem with my car, it wouldn't start one morning so I just figured maybe the spark plugs had gotten damp overnight, so I got my hair dryer and pointed it at the back of the engine toward the back set of plugs, after bout 30 minutes of this my car started right up,
I took my car to the shop and they had it for 3 straight weeks even changed the spark plugs but they never could figure out what was wrong with it. Now that it's getting cooler weather it's taking bout 2 hours of having the hair dryer blowing on the back of the engine for it yo start up, does anyone possibly know what the problem could be, thank you..
First question - Does it at least turn over?
Second question - What year of car? Does it have electronic ignition?
Third question - Does some of the hot air blow on some of the other electrics under the hood?
Yes it turns over great, it's a 2003 pontiac grand am, 6cylinder, yes the hot air blows over the whole back of the engine, I set the hair dryer where it's leaning on the edge of the coil packs to hold it in place that way I can go sit down while it's heating up
Thank you for replying
I know that J.C. Whitney sells engine block heaters that you plug into a normal wall outlet.
diogenesNY
diogenesNY
I was reading about one of those in the book that came with my car, I looked and mine didn't come with one, but in the book it says it's for really cold weather but my car started doing this back in June when it was just getting hot outside , in July and August when it would get in the 90's the car would actually crank up by itself without the hair dryer but if it didn't hit above 90 I had to use the dryer
I suspect you'll get better answers on http://cartalk.com.
Ok thank you , I'll check that out
i suspect fuel issue. Why? When it's cold it takes longer for gasoline to turn into vapor, and the easiest way to make more vapor is to have more gasoline. So by running the engine rich you have more gasoline to turn into vapor, and then you'll have enough vapor to ignite and start the engine, once you have warmed up the engine, the engine will supply enough heat to covert the liquid gasoline into a vapor.
So if you have fuel supply problem to begin with, you can crank the engine all day and you will not be able to fire the engine up. No vapor at cold temperature. The hair dryer heats up the aluminum manifold enough to get the limited fuel supply available to vaporized enough to fire.
The good news is that the 16 year old fuel pump is still operating so you may not need to drop thegas tank to change it. The fix may be as cheap as a $ 5.00 fuel check valve - see video -
I will have this idea checked out for sure, I replaced the fuel pump 3 years ago when the original one up and died on me, but this one could be dying now, thank you for replying to me
Based upon the above, you might also check your fuel filter as well.
  • · Replies 35 ·
13K
