Understanding Entanglement and Born's Rule in Photon Polarization Experiments
  • Context: Undergrad
  • Thread starter Thread starter mbond
    Born rule Entanglement
This discussion focuses on the quantum mechanics of entangled photons and the application of Born's rule in photon polarization experiments. The entangled state is represented by the wave function |12⟩ = cos(ψ)|HH⟩ + sin(ψ)|VV⟩, where ψ is the polarization angle. The probabilities of detecting photons by Alice and Bob are calculated using Born's rule and Malus's law, with specific emphasis on the correlations that arise from entanglement. The calculations confirm that the joint probability for both Alice and Bob detecting a photon does not factorize as it does for unentangled photons, highlighting the unique nature of quantum entanglement.
  • Quantum mechanics fundamentals
  • Understanding of photon polarization
  • Familiarity with Born's rule
  • Knowledge of Malus's law
  • Study the implications of quantum entanglement in photon experiments
  • Explore advanced applications of Born's rule in quantum mechanics
  • Investigate the mathematical derivations of polarization states
  • Learn about Bell's theorem and its experimental validations
Quantum physicists, researchers in optics, and students studying quantum mechanics who seek to deepen their understanding of entangled states and their measurement outcomes.
mbond
Let be an entangled pair of photons 1 and 2, with the same polarization. The wave function is
##|12>=\cos\psi|HH>+\sin\psi|VV>## with ##\psi## the angle of polarization. The first ##H## (##V##) in ##|HH>##
(##|VV>##) is photon 1, and the second one is photon 2.
Alice observes photon 1 with a polarizer oriented ##\theta_A##. The corresponding projector is
##P_A=_1|\theta_A><\theta_A|_1## with ##|\theta_A>=\cos\theta_A|H>+\sin\theta_A|V>##. The index ##_1## is to tell the projector applies only to photon 1 (not sure about the notation...). According to Born's rule, the probability Alice detects photon 1 is:
##\mathcal{P}_A=<21|P_A|12>##
##\hphantom{\mathcal{P}_A}=(\cos\psi<H|<H|\theta_A>+\sin\psi<V|<V|\theta_A>)##
##(\cos\psi<\theta_A|H>|H>+\sin\psi<\theta_A|V>|V>)##
##\hphantom{\mathcal{P}_A}=\cos^2\psi\cos^2\theta_A+\sin^2\psi\sin^2\theta_A##
After Alice has observed photon 1 (detecting it or not), the wave function ##|12>## no longer exists (it has collapsed). The probability that Bob subsequently detects photon 2 with a polarizer oriented ##\theta_B## is then ##\mathcal{P}_A## times a ##\cos^2## from the Malus law:
##\mathcal{P}_B=(\cos^2\psi\cos^2\theta_A+\sin^2\psi\sin^2\theta_A)\cos^2(\theta_A-\theta_B)##
Is that correct? I would be grateful if someone pointed me the errors...
Looks ok.
However, the bra corresponding to ##\ket{12}## should be ##\bra{12}## (one does not change the order of particles).
Let be 2 non-entangled photons ##|\phi_i>=\cos\phi_i|H>+\sin\psi_i|V>## with i=1 or 2. The wave function of the 2 photons is then
##|\psi_1\psi_2>=\cos\psi_1\cos\phi_2|HH>+\cos\psi_1\sin\psi_2|HV>+\sin\psi_1\cos\psi_2|VH>+\sin\psi_1\sin\psi_2|VV>##
Alice makes the wave function interact with a polarizer ##<\theta_A|=\cos\theta_A<H|+\sin\theta_A<V|## and is left with the wave function
##|\psi_A>=<\theta_A|\psi_1\psi_2>=cos(\theta_A-\psi_1)|\psi_2>##
The probability she detects a photon is given by Born's rule:
##<\psi_1\psi_2|\theta_A><\theta_A|\psi_1\psi_2>=\cos^2(\theta_A-\psi_1)<\psi_2|\psi_2>=\cos^2(\theta_A-\psi_1)##
A problem is that the whole wave function looks collapsed while it is only ##|\psi_1>##.
If Bob measures ##|\psi_A>## with a polarizer ##\theta_B##, he gets a probability
##<\psi_A| \theta_B><\theta_B|\psi_A>=\cos^2(\theta_A-\psi_1)\cos^2(\theta_B-\psi_2)##
which is the probability that both Alice and Bob detect a photon.
When the photons are entangled, Alice is left with
##|\psi_A>=\cos\psi\cos\theta_A|H>+\sin\psi\sin\theta_A|V>##
If Bob measures ##|\psi_A>## he has the probability:
##<\psi_A|\theta_B><\theta_B|\psi_A>=(\cos\psi\cos\theta_A\cos\theta_B+\sin\psi\sin\theta_A\sin\theta_B)^2##
but there is no Malus law there!?
Either Born's rule doesn't work with 2 photons, or, more likely, I don't apply it correctly...
If the photons are entangled, the measurement outcomes are not independent anymore, because entanglement describes strong correlations, i.e., the joint probability for both Bob and Alice detecting a photon doesn't factorize anymore as in your case with unentangled photons, which describes a state, where the photons are uncorrelated.
To see whether you calculation is correct, I'd need to know the specific entangled state the photons are prepared in. Also your notation is a bit vague!
The Born rule gives you the probability of the outcome of a measurement, but not the state after the measurement. That is given by the eigenstate of the observable corresponding to the measurement result.
I think, in principle the calculations are correct, but one should use the correct notation. If I understand it right, what's considered is the joint probability to find the photons at a certain linear-polarization state at A's and B's detector. The correct formula for that probability is
$$P(\Theta_a,\Theta_b)=\langle \Psi|\hat{P}_{A}(\Theta_A) \otimes \hat{P}_{B}(\Theta_B)|\Psi \rangle,$$
for any two-photon state
$$|\Psi \rangle = \sum_{h_1,h_2} \Psi(h_1,h_2) |h_1 \rangle_A \otimes |h_2 \rangle,$$
where ##h_j \in \{V,H\}## run over the polarization basis used to write down these vectors. The ##\hat{P}## are the corresponding single-photon-polarization projection operators.
Thank you for the answers.
I note ##|HH>\equiv|H>\otimes|H>##, the same with V. With this notation, the wave function of the entangled pair is ##|\psi>=\cos\psi|HH>+\sin\psi|VV>##. The projectors of Alice and Bob are, respectively ##\hat{P}_A=|\theta_A><\theta_A|## and ##\hat{P}_B=|\theta_B><\theta_B|## with ##|\theta_A>=\cos\theta_A|H>+\sin\theta_A|V>##, the same with B.
I would like to calculate the probability that Alice and Bob observe the same result (the entangled photons go through their respective polarizer, or are absorbed). (When ##\theta_A-\theta_B=\pm120°## I expect that Alice and Bob get the same outcome 25% of the time, independently of ##\psi##).
Then you just have to do the algebra and calulate
$$P(h_A,h_B)=\langle \psi|\hat{P}_A \otimes \hat{P}_B|\psi \rangle.$$
I guess the result will not only depend on the difference, ##\Theta_A-\Theta_B##, because that's the case only for the singlet state, ##|\psi_{\text{sing}}=(|HV \rangle-|VH \rangle)/\sqrt{2}##.
For theta=+/-120 degrees on Type I photon entangled pairs per your example: Yes. they get the same output 25% of the time when a polarizing beam splitter (PBS) is used. When a *polarizer* is used (i.e. half absorbed), the stats are different:
No result: 12.5% (of course you actually can't actually count these because they were both absorbed)
Same result (Alice and Bob record hits): 12.5% (actual would be about 14.3%)
Alice only: 37.5% (actual would be about 42.9%)
Bob only: 37.5% (actual would be about 42.9%)
"Then you just have to do the algebra and calculate ##P=<\psi|\hat{P}_A\otimes\hat{P}_B|\psi>##"
Let me do it:
##P=(\cos\psi<HH|+\sin\psi<VV|)|\theta_A><\theta_A|\otimes|\theta_B><\theta_B|(\cos\psi|HH>+\sin\psi|VV>)##
##\hphantom{P}=(\cos\psi<H|\theta_A><H|+\sin\psi<V| \theta_A><V|)|\theta_B><\theta_B|##
##\hphantom{P}=(\cos\psi\cos\theta_A<H|+\sin\psi\sin\theta_A<V|)|\theta_B><\theta_B|(\cos\psi\cos\theta_A>|H>+\sin\psi\sin\theta_A|V>)##
##\hphantom{P}=(\cos\psi\cos\theta_A\cos\theta_B+\sin\psi\sin\theta_A\sin\theta_B)^2##
But there is no Malus law ##\cos^2(\theta_A-\theta_B)## there!? (except for ##\psi=\pi/4##).
EDIT: I think my error is to use a ##\psi## angle; there is no axis there, so no angle, the probabilities for the entangled photons to be HH or VV are equal so there is a ##1/\sqrt{2}## instead.
Thank you very much for the help.
Why do you expect Malus's Law to hold here? The entangled state implies strong correlations between the outcomes of the measurements done at the two photons.
The experiments to test the Bell inequalities such as the Aspect's one are explained using the XIX century Malus law of classical optics. I think, with entangled photons, using Born's rule is much better, even if it happens to give the same result.
But Malus's Law applies to the simple measurement of a linearly polarized photon with a polarization filter in a direction of an angle ##\alpha## relative to the polarization direction of the photon to be ##\cos^2 \alpha##. That doesn't imply that the joint measurements must obey this law.
Usually they discuss as the initial state the case where ##\psi=\pi/4##, i.e., ##\cos \psi=\sin \psi=\sqrt{2}/2##. Then your formula gives obviously ##P=1/2 \cos^2(\theta_A-\theta_B)##. This is easy to understand in this case: If you put a polarization filter in ##\theta_A## direction in the way of A's photon it's projected to the state
##\cos \theta_A |H \rangle + \sin \theta_A |V \rangle## and so is also the photon at B due to the prepared entengled state. When you put a polarization filter in ##\theta_B## direction to B's photon, then you get, provided A's photon went through the probability ##|\cos \theta_A \cos \theta_B +\sin \theta_A \sin \theta_B|^2=\cos^2 (\theta_A-\theta_B)##. But now this case occurs with a probability of ##1/2##, which explains your result.
##P_{AB}\equiv P(\theta_A,\theta_B)=\frac{1}{2}\cos^2(\theta_A-\theta_B)##, right from Born's rule, is the probability that both Alice and Bob observe a photon. The probability that Alice's photon is absorbed and not Bob's is ##P_{\bar{A}B}=P(\theta_A+90°,\theta_B)##. One can check that ##P_{AB}+P_{\bar{A}B}+P_{A\bar{B}}+P_{\bar{A}\bar{B}}=1##. The probability Alice and Bob observe the same thing is ##P_{AB}+P_{\bar{A}\bar{B}}=\cos^2(\theta_A-\theta_B)##.
  • · Replies 41 ·
  • · Replies 61 ·
