- 2,167
Cthugha said:Just to summarize: my point is that "pre-existing correlations" are not "pre-existing something", but a well-defined technical term that should not be used in a loose manner as its meaning may easily get altered completely when doing so.
Wow @Cthugha , I think your focus on the word "correlations" (or "something") is way overboard, quite out of the ordinary for you. If you want to make something of the significance of momentum entanglement (as opposed to polarization entanglement) in PDC pairs and how it relates to conservation rules: Start a thread and we can discuss. But you will quickly find that it is not a factor in swapping experiments (or their interpretation), at least not one that changes anything discussed in this thread. Entanglement is entanglement, regardless of basis. Conservation is conservation as well, and nothing I say challenges this. I have written enough in this thread that trying to french fry me over a word is ridiculous. If you have something of substance, then present it.
So... I wasn't specifically trying to make the point about correlations when I wrote it, but if you want to press it: let me be explicit:
DrC: The final (1 & 4) correlations are not pre-existing independent of the BSM. Only the initial (1 & 2) correlations existed prior to that (due to MoE*). Correlations that violate CHSH are indicative of entanglement*, and vice versa.
Reference on "correlation" as you requested (the one we've been using and you apparently didn't read entirely):
https://arxiv.org/abs/0809.3991
"We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4. Violation of a CHSH inequality is not only of fundamental interest because it rules out local-hidden variable theories. It also proves that the swapped states are strongly entangled... The resulting correlations between particles that do not share any common past are strong enough to violate a Clauser-Horne-Shimony-Holt (CHSH) inequality."
Case closed, my words stand as written. You can argue with the authors over semantics if you like, but I'm done on your point in this thread. You aren't even disputing that the BSM is action at a distance.*Already referenced, and not a single counter-reference presented to date in these threads. I am not going to keep presenting references over and over.
