tezk_4 said:
TL;DR: How do we know what we know
How do we know that c is the speed limit if our instrument is based on that speed limit,
I can't follow your logic.
However, the modern derivation of relativity has nothing to do with the speed of light; it is derived from the POR (principle of relativity: the laws of physics are the same in any inertial frame). A frame is a conventional standard of rest on which experiments can be done. An inertial frame is a frame, assumed to follow the laws of Euclidean geometry in which the laws of physics are the same at all points and directions in space and at all instants of time, or a frame (again assumed to follow the laws of Euclidean geometry) travelling at constant velocity wrt an inertial frame. The Earth is, for most practical purposes, an inertial frame (although, because it is rotating, mountainous, and has gravity, it is strictly speaking not inertial).
Interestingly, the assumption of Euclidean geometry can be replaced with that of scale invariance, which is equivalent to Euclid's famous parallel postulate (and allowing the definition of an inertial frame by symmetry alone):
https://philarchive.org/archive/ULIAES
From that alone, relativity, except for the value of a constant usually called (for historical reasons) c, can be derived by logic alone:
https://www.physics.umd.edu/~yakovenk/teaching/Lorentz.pdf
Now the value of c can be measured in all sorts of ways, many not even involving light. It always turns out to be the speed of light. Which, by the POR, means that speed is the same in all inertial frames.
Apologies to Berkman - penned my reply while you were closing it.
Thanks
Bill
